First post, by Dominus
- DOSBox Moderator
You really need to help me out, my memory is shot and I'm not sure how to do a search on this 😀
If you want to "expand" the existing PATH environment, what is the correct way? I know I used to know it but at the moment I just can't remember 😀
With "Set PATH=..." the existing path setting gets overwritten... Was it "Set PATH=%Path%..."?
Edit: seems that was it, at least that works in Dosbox 😀
