Any KVMs for under $50?
First post, by THEBaratusII
Is there any affordable KVMs that mainly work with computers that have both USB/PS2 ports for under $50 or maybe lower? I don't care too much about VGA as I use a Datapath VisionRGB E1 and just project the screen via OBS. Same about audio.
The main reason I am considering one is that I have an L-shaped desk. My main PC is on the front and the other machines I use are on the left side and it's starting to feel uncomfortable to use. (One of my elbows are even touching the other side of the desk as well)
I feel like this would also eliminate the need of using my other PS/2 keyboards/mouses as well.
To clarify more, I mostly use older machines with a PS/2 kb+mouse while on my main rig is just a USB mechanical keyboard and a Zoewi USB mouse.
My Website
YouTube Channel
Reply 1 of 3, by RandomStranger
Maybe it's enough to get a USB switch and a Y cable?
I use this model of switch to switch mouse/keyboard between my W7 thin client and daily driver PC:
And I'm planning to get something like this for my W98 PC:
Or maybe these:
I have one laying around for mice, but never tried.
Otherwise I used a D-Link DKVM-2KU to switch between 2 retro/nostalgia PCs. It was cheap, works fine and discontinued.
https://www.dlink.com/en/-/media/consumer_pro … sheet_en_uk.pdf
https://www.dlink.com/-/media/Consumer_Produc … U_QIG_EN_UK.pdf
Reply 2 of 3, by chinny22
I went the other way and use PS2 style KVM's as almost all my computers have PS2 ports. Bonus is they are typically cheaper, especially second hand.
although I use a PS2 keyboard, mouse is a USB optical mouse with USB adapter like the 3rd pic in the above post.
For the 2 PC's that don't they are modern enough to support cheap PS2 to USB HID devices like this.
https://www.amazon.com.au/GELRHONR-Adapter-Ke … d/dp/B089QG9Y6H
Reply 3 of 3, by THEBaratusII
The USB Switch method sounds interesting, however I don't know exactly how this would handle using my main PC's keyboard and mouse. I could try converting them from USB to PS/2 but my main PC's motherboard lacks PS/2 ports. So it'll be like USB to PS2 to USB practically, and could potentially lead to various amount of issues I think.
The problem could technically apply to using older PS/2 style KVMs. Meanwhile while my finance is in a tight situation, I decided to reorganize my L-shaped desk for the time being. Basically two keyboards and mouses in the front of the desk that could swap places whenever I feel like firing up one of my older machines. It'll do until things are sorted out, then maybe I could look into trying KVMs in case one or few of the devices I ended up buying doesn't work out as expected.
Do keep me updated, because a way to share keyboard+mouse that are both compatible with machines both with USB and PS/2 does seem to be a convenient idea in the long run.
My Website
YouTube Channel
