First post, by Retroinside
- Newbie
Hi guys!
I was working in this days on a Slot 1 Platform (Iwill VD133Gold board), tryng to perform a decent overclock for a Celeron Mendocino 333 MHz.
Had a 90 radiator and an universal chipset water block aside. I easily recovered a universal pump from China and created a small, but efficient liquid cooling system for my Celeron Slot 1.
I'll be honest, I was hoping to get more. Unfortunately, however, the motherboard does not allow me to increase the CPU voltage as I would like. With some Jumpers , it allows me to increase the vcore by 10% or 5%. Same thing for the VIO too.
However I was hoping to be able to push it to something beyond 2.3 (I know that up to 2.5V is manageable, if properly cooled).
I attempted pin mod of pins a119 and b119. Without any success alas. The motherboard just won't POST with this change. I also tried covering the pins individually but again, no success.
I therefore ask for advice from any of you, if you have ever tried this practice, and can provide me another solutions.
At the moment I am stable with a poor vcore of 2.2 V, at 525 MHz (105 MHz FSB X5.0) but I can pass POST even at 550 (110 MHz X5.0) but it won't load OS.
I am therefore sure that already with a decent voltage I would see at least 550 MHz stable.
At the moment I can even get close to the performance of a 500 MHz K6-2+
here a video of my tests of this weekend
