First post, by kotel
- Oldbie
Hi
While back I got an DELL 2007WFPb LCD monitor as scrap. After first power on the monitor displayed for a while then screen was going black (w10 also did the disconnect sound!). Blue LED on power button was still lit. Inside there were 2 bulging caps (both 220uF 25V) on the backlight PSU. Replacing them didn't help. Forgot to check with a flashlight if it was displaying anything. Then I've assumed it was the backlight PSU which was bad and it went into the attic for a while.
Now I've faced a similar problem with an LG 19" LCD monitor which had bad backlight. Same symptoms, although w8 did no disconnect sound and it was still displaying (I could see with a flashlight). Removed the old tubes and did a LED conversion. After that it worked perfectly, so I was pretty confident about fixing this DELL.
On first disassembly I broke off most of the pins of the front PCB connector. Repaired that and re-checked for short more than 20 times. After confirming everything was connected I got a dim green power LED. It wasn'tturning on. Then I have missed two shorted traces and after fixing that it turned orange. Now it's back to green and still not turning on. All the cases I've seen were related to it stopping displaying stuff after 3 seconds with blue LED lit. No dimly lit green/orange power LED (power button). Currently I'm out of ideas where to go next, so I'll ask here if anybody could guide me with fixing this monitor up.
"Sent on a mission, to protect the last treasures. Through struggle and strife we can see the light. Even if our mission is partially complete, Our efforts are not in vain.
Let that be our legacy."
-Stronghold 5-5
