First post, by Jackhead
I have a MCB-1 for my LAPC that makes permanently noise when my system is in idle.
The noise sounds like a coil or something. So i open the box to check where the sound comes from.
Its that blue speaker like thing.
When i use the breakoutbox its gone.
Is this just a buzzer? And when yes, for what?
The attachment IMG_E7509.JPG is no longer available
The attachment IMG_E7510.JPG is no longer available
Reply 1 of 5, by nocash
Looks like a piezo speaker. As it's close to the tape/metronome connectors, it might be just that for. You would have to look a the bottom side of the PCB to see if connects to those connectors.
Reply 2 of 5, by Jackhead
a speaker for the metronome make sense! Will check the lines.
Reply 3 of 5, by keropi
if the speaker is indeed the issue then you can just desolder one of it's legs , make sure it does not make contact and just leave it inside the box
that will shut it up 🤣
🎵 🎧 ⏳ ⚡ SoundVision PRO,MK1869 , PCMIDI MPU , OrpheusII , Megacard and 🎶GoldLib soundcard website
Reply 5 of 5, by AppleSauce
Yeah given the original break out boxes were designed for musicians rather than gamers or casual users they had features like a metronome and a din sync connector for drum machines plus tape sync.
