S3 Virge PCI problem
First post, by Half-Saint
I have two identical ExpertColor S3 Virge PCI VGA cards that both have this problem. The image on screen doesn't go from edge to edge but is instead vertically narrowed by about 20% and much lighter than normal. I'm using a 24" LCD monitor and a VGA cable both of which I always use for testing old hardware.
Any ideas what could be causing this? I'll try to attach a photo soon.
Reply 1 of 11, by zami555
At which resolution and refresh rate have you experienced this issue? Does it change with different resolutions?
Reply 2 of 11, by Half-Saint
zami555 wrote on 2024-10-22, 09:11:
I get this immediately on startup. Haven't tried anything else as I was put off by this and it didn't occur to me to try other resolutions.
Reply 3 of 11, by Joseph_Joestar
The brightness thing is a known issue with S3 cards from that era. The ones made by reputable manufacturers like Diamond, Hercules, STB, Elsa etc. usually don't have this problem, but many others do. In some cases, this can be fixed through software, or by swapping out the BIOS.
See this thread for more details: S3 AGP Cards (and possibly others) Too Bright
Reply 4 of 11, by Half-Saint
I'll stick the card in my win98 machine and see what happens when windows loads.
Reply 5 of 11, by zami555
Joseph_Joestar wrote on 2024-10-22, 09:21:
@Joseph_Joestar thanks from my side for sharing the link to that topic. Till now I thought the issue with too bright display in DOS was related to just AGP cards from S3. Thanks to deeper study of linked topic I now understand that it could also affect PCI cards. Everyday a new knowledge 😀 .... just memory deteriorates faster with every New Year 😉 ....
Reply 6 of 11, by marxveix
Half-Saint wrote on 2024-10-22, 16:50:
Lighter issue does not go away by itself i think, I have one S3 Virge GX2.
Best ATi Rage3 drivers for 3DCIF / Direct3D / OpenGL / DVD : ATi RagePro drivers and software
30+MiniGL / OpenGL Win 9x dll files for all ATi Rage3 cards : Re: ATi RagePro OpenGL files
Reply 7 of 11, by Half-Saint
marxveix wrote on 2024-10-22, 17:01:
Maybe not but I need to see what happens at higher resolutions. If the image remains squashed or not.
Reply 8 of 11, by Half-Saint
I just finished a quick test. The image appears washed out in DOS but not in Windows. The "letterbox" is also visible only on the first screen (see photos) but not on the next one where DOS begins to load. All in all very weird but I'd say the cards are not actually defective as such.
Reply 9 of 11, by st31276a
The resolutions of the two screens differ.
If the colours look good in windows where the driver programs the card, it could be a buggy video bios.
Reply 10 of 11, by Half-Saint
st31276a wrote on 2024-10-23, 10:39:
The colours look good but video quality leaves a lot to be desired 😁
Reply 11 of 11, by st31276a
A buggy video bios *and* a crap analogue circuit.
Sometimes there are RF chokes in the output path of these cards that can be shorted to pass more high frequencies, making the image sharper.
