Bought this (Modern) hardware today
Reply 2120 of 2188, by konc
H3nrik V! wrote on 2024-10-19, 16:19:
Any suggestions? And can a CPU be toasted like that - seemingly working but no OS boot?
I'd suspect the motherboard and what it's trying to do with the unlocked CPU. Maybe there is a way in BIOS to stop it from "optimizing" anything, just to see if that's the case?
Reply 2121 of 2188, by H3nrik V!
konc wrote on 2024-10-20, 08:56:
So, I borrowed another 9th gen rig to test the cpu, same symptoms. Except, if I limit the number of cores from BIOS. 1-4 cores boots windows fine, more, and no luck. Seems like one core is somehow damaged. Hopefully seller will accept a return ..
Reply 2122 of 2188, by RandomStranger
Picked up this today to upgrade my old speaker set.
669.69 KiB
748.71 KiB
678.68 KiB
Smaller than expected, AAA battery for reference
I think I'll pick up a phone charger with 2 or maybe 3 USB ports to free up some wall sockets. The manual claims it can pair with up to 8 devices.
Reply 2123 of 2188, by konc
H3nrik V! wrote on 2024-10-21, 21:29:
Wow so modern CPUs can be partially cooked. Good to know and good job spotting it.
Reply 2124 of 2188, by Sombrero
konc wrote on 2024-10-24, 10:45:
You might want to look up what has been happening with Intel 13th and 14th gen CPUs lately.
I wouldn't recommend getting one second hand.
Reply 2125 of 2188, by konc
Sombrero wrote on 2024-10-24, 10:52:
Yes I am following that, but never thought that a bad CPU can load Windows when halved and the bad cores are left out. It makes sense though. A bad CPU used to be obvious, failing everywhere. Now it's more tricky to spot and the symptoms resemble those of memory problems
Reply 2126 of 2188, by H3nrik V!
Well, I contacted the seller, who told me that he'd only tested it to BIOS (which I until a couple of days ago would've thought was fine) and agreed to look for a replacement, or he will refund me 😀
Reply 2127 of 2188, by dormcat
Ordered a strip of 4GB DDR3-1333 for my ThinkPad X200, as it rejects either 8GB DDR3-1333 or 4GB DDR3-1600. After searching the auction site Shopee I found a cheap 4GB-1333 strip with the same make and model of my existing strip, down to the same chips.
119.64 KiB
seller's photo
Then I received a 2GB strip. 😠 Fortunately I recorded the entire opening process in video.
60.36 KiB
I've contacted the seller and see if he can respond promptly; if not I'll report him and demand a return / refund.
UPDATE: Refund successful, but in credits instead of cash. 😅
Reply 2128 of 2188, by brostenen
Paid for this one, for the equivelant of 112 USD including shipping....
It is for my son. He grew tired of his Ps3, and sold it for the equivelant of 58 USD (including 2 controllers and 4 sports games)
He gave me the task of finding some Xbox One S in good cosmetic condition, and I promised to pay the difference for him.
I kind of think that I cracked that nut to an A++. Also.... I found an X and not S. So that is a bonus, he did not expect.
409.68 KiB
479.54 KiB
291.21 KiB
296.52 KiB
Reply 2129 of 2188, by BetaC
Don't tell intel I have one of these...
319.74 KiB
Well, I don't really think they actually care any more, but it's still just kind of hilarious that this sticker is on the bottom.
342.31 KiB
As far as I can tell, it's one of the 61 core P54C based models, complete with 16GB of ram built in. I don't picture myself using it, but it's nice to have. I can now display it alongside my i740 card. In my two part collection of "Intel made that?" products.
932.52 KiB
Reply 2130 of 2188, by Hoping
I got this motherboard, I was interested in it because of all the connections it has, Floppy, IDE, SATA2/3, USB2/3; what interests me is the floppy drive connection on a fairly modern motherboard, it comes with a FX 6300 which should be pretty good for Win7 32 and XP.
I plan to use an M2 SSD, modding the BIOS to make the M2 bootable, like I did on the Asrock 4core1600p35-wifi; but as you can see, it only has one PCIE X16 and three PCIE X1, they are 2.0, so the maximum speed of an M2 SSD on PCIE X1 2.0 I think is 800 MB, little faster than SATA 3 in theory.
I'm curious, is it possible to use the three PCIE lanes of the three X1 slots at the same time, or two lanes from the two slots that are closer, for example, modify a X4 riser cable and add two more connectors only with PCIE lanes to make something like a PCIE X3 connection, I know that there were M2 X2 SSDs.
All the lanes should go to chipset so; I wonder if something like that would work, isn't it especially difficult to do, but, can anyone give me an opinion if it would work?
    1.41 MiB
Reply 2131 of 2188, by Intel486dx33
Guys, this is the Best sounding Mini Bluetooth Speaker of this size.
It has two speaker drivers inside and sounds great.
I compared to other small bluetooth speakers of this size and this one sounded the best.
This speaker sounds better than other speakers this size selling for $100
It has a Nice Natural balanced sound with good base and treble.Easy on the ears for hours of listening enjoyment.
THX and Dolby Audio sounds really good on this speaker. Great for watching Movies or Music.
Clear audio with NO distortion. Movie theater sound from a tiny speaker.
It has good battery life up to 24-hours of continuous play
Hold a charge for many days.
Fast USB recharging
IPX-7 Waterproof
Small enough to fit in a small back pack or small purse or messenger bag or your pants front pocket or jacket pocket.
It’s perfect for mobile people on the move.its small and light but packs a punch.
Great to use with a phone or tablet or notebook.
It has a 3.5mm speaker wire port connection too so you can hook it up to a small TV or your Retro Computer.
Makes for a great gift or Stocking stuffer.
I buy these 5 at a time and give then out as gifts when ever I need one.
    326.27 KiB
    299.17 KiB
Reply 2132 of 2188, by H3nrik V!
Bought a Cooler Master HAF-XB, which also works perfectly as a test bench. Well, actually, I do have my daily driver in one of those, but since my test setup rests on top of a stack of Milwaukee PackOut toolboxes, I wanted to be able to move it around in one go, rather than balancing ODD, HDD, FDD, PSU etc. on a motherboard tray.
https://www.coolermaster.com/en-global/produc … /?tab=tech_spec
Reply 2133 of 2188, by MAZter
https://www.aliexpress.us/item/3256806731608773.html
Saroo Cartridge for Sega Saturn, newest revision 1.66
43.26 KiB
68.82 KiB
87.27 KiB
Reply 2134 of 2188, by Nexxen
be quiet! 650W Dark Power Pro 11
80+ Platinum
the thing is heavy and albeit being old it still works perfectly. It's intended use is testing stuff.
PC#1 Pentium 233 MMX - 98SE
PC#2 PIII-1Ghz - 98SE/W2K
Reply 2136 of 2188, by Nexxen
Sapphire PULSE RX 5600 XT
More than I really need but will last forever.
Just bought Control and will see how it fares. The games I play are older than the card.
Still have to go through Doom Eternal.
Reply 2137 of 2188, by BetaC
Today I finally left the 1080p world. I upgraded to a Genuine Smasnug G60SD OLED monitor because it was both available locally, and $250 off. It certainly outdoes the 5151 I have in the same room to say the least.
734.64 KiB
I'm looking forward to being able to see less of the problems that come from modern rendering techniques through the power of higher DPI and a higher resolution hiding how bad DLSS actually looks when you can see individual pixels.
Reply 2138 of 2188, by UCyborg
I got a dedicated sound card and open-back headphones previous week, a Creative Sound BlasterX AE-5 Plus and Beyerdynamic MMX 330 Pro. Sound card was ordered from local web shop, headphones were ordered directly from manufacturer from Germany, they were giving away speakerphone Beyerdynamic Space (aquamarine flavor) for orders above 299€.
It's an upgrade from usual cheap stuff, you can definitely pick up on details that weren't audible before.
Arthur Schopenhauer wrote:
A man can be himself only so long as he is alone; and if he does not love solitude, he will not love freedom; for it is only when he is alone that he is really free.
Reply 2139 of 2188, by pete8475
UCyborg wrote on 2024-12-19, 21:59:
Flavor? 🤣
I haven't tasted sound since I did some LSD in the eighties.
