First post, by jasa1063
- Oldbie
I just got an Alaris Cougar motherboard with MR BIOS. I am running it at the default 25MHz FSB speed. I cannot get any of the two VLB video cards I have to work. One is Cirrus Logic 5426 and the other is a Cirrus Logic 5429. Both video cards work just fine in my Alaris Leopard motherboard. Cirrus Logic video cards are usually very compatible. I have tried changing the jumpers for the VLB settings at JP4, JP5 & JP8. I took the back plate off both video cards to make I could seat each VLB card all the way down into the VLB slot. I also used DeOxit5 in both slots. Everything I have tried so far does not work. I am currently running with a Micro-Labs ET4000 True Color ISA video card set to 0WS. I would expect the video performance to be at around 6MB/s with the ISA bus set to 12.6MHz, but I am only getting 2MB/s. I am unable to get any faster performance than that despite changing the BIOS settings. At this point I have run out of ideas. Any suggestions would be greatly appreciated.
Thanks!
