Eimer wrote on 2024-11-04, 20:01:
I went with the additional jumoper configuration guide here...
https://theretroweb.com/motherboard/manual/cp … 56022401852.pdf
I guess the first configuration on the sheet should be correct, but the manual states something different for P24D and P24CT..
Exactly. The DX4 with write-back cache is exactly what they mean by "DX4 &EW". It's also identical to the Am5x86 jumpering (except for JP20 1-2 is 2x for the DX4 and 4x for the 5x86), which confirms the settings to be appropriate, as this is the only difference to be expected. I get suspicious though, as the table does not clearly specify how to jumper WB mode. "JP21 2-3 short for WT" is not followed by "(all open for WB)", although this is clearly a jumper connected to the WB/WT pin (which is the 2x/3x selector on the AM486 NV8T). Furthermore, it is completely left as an exercise to the reader what to do with JP16 for WB mode: Should you just skip 5-6? Should you have it "all open"?
As the WB configuration is clearly not described in the settings guide, I'm afraid that possibly the WB mode does not work correctly and got redacted from the jumpering guide, so you are on your own regarding that.
The differing configuration for the P24T (PODP) is due to the 237-pin package instead of the standard 168-pin package. Ignore the PODP jumpering.
