First post, by SirAngelbane
I have a Dell 333s/l (386/33) that I currently have booting off of a 512K San Disk CF card on the on board IDE to do this I have to use a Lo-tech ISA XT CF Adapter rev. 3 to load the XTIDE Bios (IDE_386.bin).
The XT CF Adapter is jumpered to use address C800h. (IO is 300-31Fh)
The EEPROM im using in the XT CF Adapter is a SST39SF040.
I want to add a network card to this system but the problem is that to do so I will have to replace the XT CF Adapter as there will not be any free slots in the machine to simply add another card.
I am attempting to use a Intel 8/16 lan adapter as that is the only ISA network card I have that has a 32 pin option rom socket.
But when I put the EEPROM onto the lan adapter and replace the XT CF Adapter with it the XTIDE bios does not load and the system will not boot off of the CF Card.
The when I use Softset2 to config the lan adapter it appears to work and it will save config changes.
After a reboot it will not detect the bios ROM and CheckIt Does not show adapter rom at C800h to CA00h.
When I put the rom chip that came with the lan adapter (A P28F020) back in and reboot.
Softset2 will detect that ROM and CheckIt Shows 8K adapter rom at C800h to CA00h.
However im not sure what is on that rom and the system will not book off of the CF with it in.
I was thinking maybe the SST39SF040 isnt compatable with the lan adapter but I cannot find anything that says it would not be.
I have not been able to determine what im doing wrong and at a loss to what to try next,
Any suggestions would be appreciated as I have been struggling with this for days now trying a bunch of different things.
I dont have an stand alone EEPROM programmer so I dont have a way to flash a 28pin EEPROM to try on a different adapter.
I be open to trying a 28 pin EEPROM but finding the right programmer and the EEPROM to go with it and learning to use that is a bit daunting.
SoftSet2 Config of the lan adapter.
I/O Address: 300 - 30fh
Interrupt: 5
Connector: Auto
Force 8bit: No
Amount of Ram Mapped: None
Ram Start Address: None
Flash/Boot ROM Address: c800 - c9FFh
