Reply 2040 of 2055, by rcblanke
- Oldbie
Indeed, there are some new lines: 242-243, 550-555, 818-821 and 867-868 .
Done.
Hi rcblanke, have you dropped support for Windows 8.1 in the latest dbgl099rc1 build? I did a clean install and when I run it nothing happens. Dbgl098 final is still working. I'm currently using Java SE Dev Kit 21.02, so in regards to Java it should be compatible.
Thanks!
Thank you Neville!
PerryRhodan, no, as long as Java 17 or newer is installed, it should work. Do you get any interesting output when you try to run dbglcons.cmd in a terminal window?
Hi Rcblanke, I ran dbglcons and it's come up with the error, 'unable to access jarfile dbgl.jar'. I have no idea what's causing this as the file is in the DBGL directory. I've also updated Java runtimes and SDK to the latest versions.
Thanks!
Update: I tried the new DBGL update in Windows 11 and it worked straight away. I also tried it in Windows 7 and like Windows 8.1 it didn't work, so I can only presume that it no longer supports Windows 7 & 8.1.
Thanks!
I have a quick question regarding translations. I know that I must translate options, descriptions... but what about parameters? Like these ones:
Because I'd like to provide the most complete translation possible, but I wouldn't want to break anything or confuse users.
Ah, indeed it seems that Win7 and Win8 support has been dropped in the most recent SWT release. So that explains the problem you mentioned, PerryRhodan, thanks again for letting me know. Though it seems that folks are working on patching at least some support back in, see https://github.com/eclipse-platform/eclipse.p … m.swt/pull/1568 . Also, it should be perfectly fine to use lib/swtwin64.jar from DBGL0.98 in the upcoming DBGL0.99 if you really need to use Win7 or Win8.
Thank you Neville, I do not plan on having the parameters/values for the DOSBox settings translated. These values are stored directly in the profile .confs, and therefore I believe it would be best to keep them in English.
Alright, then. One less issue to worry about.
Hi rcblanke, Most of my favourite apps, Launch Box 13.7, various emulators, Steam, Ubisoft, Epic Games, India Gala and Outlook have now dropped support for Windows 8.1. So now it looks like I have no choice but to use Windows 10 as my main OS from now on. Oh well, Sigh!!!!!
Thanks!
Just dropped by to say I installed the RC1 and wanted to give kudos to rcblanke - this is an amazing update to an incredible piece of software.
Thank you so much for all the work, making these gems more accessible for a new generation. This is priceless for preservation.
Thank you so much GabeCube!
I've just uploaded the second release candidate with some minor changes. When hovering over a configuration item in the profile editor, a small tooltip will now show the DOSBox configuration [section] & item associated with it. Also, I've added support for converting and importing eXoDemoScene.
Ronald
Hi all,
I've released DBGL 0.99 on the website. Compared to RC3, the only thing changed is added support for DOSBox-X 2024.12.04 . Thanks again for the translations and all the feedback, this release has been quite the undertaking.
Regards,
Ronald
Yay! Thansk for all the hard work, rcblanke.
Hi, I'm using Debian 12 now, and just installed default-jre and have tried starting DBGL but it doesn't open. Just a flicker, then gone. From the terminal, the following were displayed :
malik@debian:~$ dbgl
Launching DBGL using 64-Bit VM 17.0.13 on Linux v6.11.5+bpo-amd64amd64, HSQL Database Engine 2.7.3, SWT v4966gtk
Startup
(SWT:8655): Gtk-WARNING **: 16:58:23.182: Negative content width -9 (allocation 4, extents 6x7) while allocating gadget (node separator, owner GtkSeparatorToolItem)
(SWT:8655): Gtk-WARNING **: 16:58:23.183: Negative content width -9 (allocation 4, extents 6x7) while allocating gadget (node separator, owner GtkSeparatorToolItem)
Exception in thread "main" java.lang.ArrayIndexOutOfBoundsException: Index -1 out of bounds for length 1
at org.eclipse.nebula.widgets.gallery.Gallery._getItem(Gallery.java:1745)
at org.eclipse.nebula.widgets.gallery.GalleryItem.getItem(GalleryItem.java:245)
at org.dbgl.gui.controls.ProfilesList.setSelection(ProfilesList.java:370)
at org.dbgl.gui.dialog.MainWindow.onShellOpened(MainWindow.java:269)
at org.dbgl.gui.abstractdialog.BaseDialog.open(BaseDialog.java:116)
at org.dbgl.gui.Launcher.main(Launcher.java:55)
It opened for 2 or 3 times at the very beginning, and then doesn't open anymore. Tried with openjdk-17-jre without default-jre but it doesn't work too.
Thanks for reporting Malik, you seem to have spotted a minor bug in the SWT Gallery code. Easy to work around, though, please update dbgl.jar to 0.100beta1.
