First post, by papazark
Hi
Sorry if the question has already been answered before ...
I'm trying to mount a folder using dosbox command line, and execute some command after that. (such as iso CD mount, cd and bat file)
But it seems dosbox tries to execute the [autoexec] section of the conf file first, (which fails because C isn't mounted yet) and then mounts the directory I passed as a parameter.
According to the readme.txt, it seems to be the correct behavior (like the -c parameter), so is there a way to do the contrary ?
Thanks for your answers
