First post, by Robin4
As the title already reveals, iam looking for a eeprom replacement for an Macronix MX 28F1000PL
As it seems, its not compatible with an Intel P28F001BX-T or a ST SST PH29EE010. Guessing the have a different pin lay-out.
Is there a 1:1 substitute for this IC?
Reply 1 of 5, by Horun
The MX is a block type 16kx6 block + 4kx4 (112k +16K), Intel BX-T is a block type 112k + 4kx2 + 8k (112k + 16k). The pinouts appear the same from the datasheets so if BX-T is programmed from a external programmer it should work but I quickly checked the data so maybe not..
Reply 2 of 5, by Robin4
Do you know a substitute for the MX part? Or is this the only part with that configuration?
My Mini pro TL866CS cant read the chip in almost every chip selection.. I tried different ones, but those doesnt seems to work.
Reply 3 of 5, by Horun
Hmm maybe something wrong with the eeprom, from TL866 device list: MX28F1000P, MX28F1000P @PLCC32, MX28F1000P @TSOP32 reading the software support list.
http://www.autoelectric.cn/MiniPro/MiniProSupportList.txt
Reply 4 of 5, by Robin4
I thought the same on maybe bad eeprom.
Should this be the same:
MX28F1000P
Only difference on mine is the L behind the P (maybe its an low voltage one)
Reply 5 of 5, by mbarszcz
In case anyone stumbles across this thread in the future, the MX28F1000P is definitely a different chip than the MX28F1000PL. I needed a new BIOS chip for a PC Chips M575 but I was only able to find the MX28F1000PL available. The original chip was an rebranded Macronix MX28F1000P as "H.T. M21084" (ID: C2 1A) as a and the replacement was a MX28F1000PL (ID: C2 11).
I've been unable to find a datasheet for the MX28F1000PL, but UNIFLASH was able to report the differences between them. In uniflash:
my original MX28F1000P BIOS chip is reported as "Macronix MX28F1000P/24V, Organization: sectored: 7x16k, 4x4k (128K)
my replacement MX28F1000PL chip is reported as "Macronix MX28F1000/12V, Organization: sectored: 8x16k (128K)"
I'm not entirely sure what that extra 4x4k is, but I suspect it has something to do with what the BIOS refers to as its "NVRAM" area. With the MX28F1000PL installed, the BIOS reports "No NVRAM". With the Original it reports "NVRAM OK". This doesn't seem to have a functional impact on the system, but it must try to store something there and can't with the MX28F1000PL.
