First post, by RobbieBenzi
Hello there, I'm trying to Boot win2k from a logical partition in XOSL, I have 3 other primary partitions dedicated to other OSes but I want to have a dedicated boot entry for 2k not relying on the other primary partitions.
XOSL itself can mark the 2k partitions as Active, but even if I Copy the NTLDR file, the boot.ini file and the ntdetect.com files to the 2k partition I can't Boot It, I think the problem lies in the 2k VBR of that partitions that is unable to "launch" NTLDR.
I have 8mb unallocated space before the 2k partition.
Is there a way to copy the bootable VBR in that free space or to hex edit the win2k VBR to make It launch NTLDR?
Thank you
RobbieB
Reply 1 of 9, by bakemono
What do you mean by "logical partition"? You can have 4 primary partitions in an MBR. Win2k should be able to live on any of those.
Installing the VBR (which is 7 sectors long BTW) and populating the BPB with the correct values to make it boot has always been more complicated than it should be. Use disk manager or BOOTSECT.EXE from a running Windows NT OS, use a sector editor, or use some third party utility.
Wreckage reimagined on itch: https://90soft90.itch.io/wreckage-dash
Reply 2 of 9, by Ryccardo
http://www.goodells.net/multiboot/ has literally your case 😀
In short - clone a known working installation to the logical partition (copying individual bootloader files may be possible for 2000 but is asking for trouble in DOS-based stuff), edit the NTFS header so that it has the correct "hidden sectors" = starting LBA, and the boot.ini to point at the right partition number!
Reply 3 of 9, by javispedro1
grub4dos can also boot ntldr directly.
But I don't think the hard part is getting ntldr to boot, but rather getting ntldr to collaborate. ntldr, specially pre-XP versions, is full of bugs. It hardcodes looking for ntdetect, boot.ini, etc. on the active primary partition. It will get confused if the VBR on memory used to boot it doesn't match the one from the active partition on the disk. Etc.
Reply 4 of 9, by Kahenraz
Doesn't booting like this with another active primary partition cause Windows to be on the D drive and the C drive to be whatever else was primary?
I remember having weird problems the last time I experimented with this.
Reply 5 of 9, by javispedro1
Kahenraz wrote on 2024-11-13, 18:28:
Yes, but this is a cosmetic issue mostly. I am not sure why it annoys people so much. And drive letters can be rearranged, even the system drive, on NT post-installation (I once did it just with regedit...).
Reply 6 of 9, by Kahenraz
It's more than cosmetic. There are a lot of games and software that assume that Windows and Program Files is on the C drive. It causes a lot of headache on those corner cases.
Reply 7 of 9, by chinny22
Kahenraz wrote on 2024-11-14, 17:39:
I would change alot to very few.
Ever since we got our P2 in 1999, I've typically had the below setup.
C:\ Win9x
D:\ Data, Games, Etc
E:\NT4, 2k or XP (depending on the era)
Only game I can remember not liking that setup was Hi Octane, which was a dos game that wanted its own folder in the root of c:\
Reply 8 of 9, by javispedro1
But such software would also break on all non-english versions of windows, since Program Files will not be called "Program Files". Or does software out there actually hardcode "C:\$LOCATION_OF_PROGRAM_FILES" (assume the directory name is variable while the drive letter is not?).
Reply 9 of 9, by chinny22
javispedro1 wrote on 2024-11-14, 22:50:
Badly written software is programmed to common locations, like c:\program files. I remember it been a bit of an issue when profiles moved from :\documents and settings to :\users
I found accounting software was the worst. I guess as its a small market as each county has it's own preferred software.
However most software is programmed to use variables, eg %SystemRoot% will always take you to windows folder of the copy of windows you booted from, even if its a different name and/or drive
