First post, by mrzmaster
- Member
Hello,
For the past several years, I've been very slowly collecting parts for a build centered around an Asus P5A-B and Pentium 233MMX. I recently acquired one of the final parts for this machine, a NOS baby AT style case with a NOS AT power supply. The case has an LED display (as well as a turbo switch) on the front to show the clock speed of the CPU. I'm assuming the display gets fed by the turbo LED header connector, however, the P5A-B does not appear to support this.
Is there any way to get the case's LED display to show the CPU clock speed using this particular motherboard? Thanks!
