Reply 28780 of 31977, by CMB75
- Member
I've spent a lot of time testing the components I've purchased recently. Since these were all declared as good and tested, I wanted to know what condition the parts were in before storing them.
Surprisingly, most of it worked right away but I had a few problems with the ASUS P5A-B. To test the baby-AT motherboards I used the old IBM Model M keyboard.
While it did work just fine with the Soltek SL-54U5 the plug just didn’t fit into the DIN socket of the ASUS P5A-B. So I tried using the keyboard from my TA1700 80186 which did fit but didn’t work (missing keyboard error) - maybe that’s the same unidirectional pin layout as the IBM Model F.
Then I got in my workout, basement, attic, basement, attic, ..., I knew I had a DIN-PS/2-adapter on the Microsoft Natural Keyboard. It took me half an hour to find the keyboard but of course the adapter wasn’t connected. I'll just order a new adapter, then the old one will present itself after a short time anyway.
