D-Fend Reloaded (DOSBox frontend)
Reply 2280 of 2281, by IIGS_User
breshar wrote on 2024-02-13, 18:41:
I use D-Fend Reloaded 1.4.4 for quite a while now. I've added about 400+ entries, also making separate entries for modded games like Commander Keen or Doom.
This version of D-Fend Reloaded is outdated, and ScummVM probably changed the file format, so D-Fend Reloaded doesn't know how to read it.
Klimawandel.
Reply 2281 of 2281, by Ohrensessel
just was strolling through the forum yesterday to see if there are any new interesting posts and stumbled across the D-fend Reloaded thread and saw that people complain that Dosbox-X is not really supported in D-fend Reloaded. I am using Dfend Reloaded since a lot of years. Unfortunately I started with my games database (way more than 1000 games and software until now) before development of D-fend Reloaded ended, so I am now stuck with it. On the other hand it worked flawlessly until now, even with Dosbox-X. Just had to add a new Dosbox installation under Program options, point to the Dosbox-X folder and rename the exe from dosbox-x.exe to dosbox.exe. Any additional settings (like for example for MT32, used soundfonts or printing) can then be added in the "Custom settings" field under "Dosbox settings", though I have never tried Voodoo support until now. So I never had the need to even touch the dosbox-x.conf file. Just lately I had a problem with the Z drive path (Z:\;Z:\SYSTEM;Z:\BIN;Z:\DOS;Z:\4DOS;Z:\DEBUG;Z:\TEXTUTIL). Seems with newer versions of Dosbox-X the path needs to be added by hand in the DOS environment settings of D-fend Reloaded.
Maybe someone finds this helpful.
Ohrensessel
