First post, by DustyShinigami
- Oldbie
Hi
I've run into a few minor technical issues with Windows 98 SE. The main one I'd like to sort out, if possible, is that the Windows 98 logo no longer appears during boot, which I'd like for it to again. I think it's due to the amount of drivers that load up in DOS beforehand? I read that adding a command in msdos.sys called LOGO=1 should sort it, but it hasn't for me. So I figure the only way around it would be to delay the drivers that load on boot...? Is it possible to set them to load only if I restart into DOS or boot into it on startup from the boot menu?
The other problem is that, often, once I've booted into Windows, it will throw up an Illegal Operation Error related to Explorer.
Clicking OK causes the Nvidia Control Panel and my onboard audio controller to disappear from the bottom right. Because it affects the Nvidia Control Panel, I figured it could be the drivers that are the problem? So the only thing I can think of trying at some point are some different drivers.
And similar to the previous issue, my Safely Remove Hardware icon has completely disappeared and I can't get it back. Someone on Reddit suggested I re-install the USB device drivers, but that hasn't worked sadly. The only option I have is to Eject the device from My Computer. A minor inconvenience, but would love to get it back if possible.
Thanks
OS: Windows 98 SE
CPU: Slot 1 Pentium III Coppermine 933MHz (SL448)
RAM: Kingston 256MB 133MHz
GPU: Nvidia 16MB Riva TNT/128MB Geforce 4 Ti 4200
Motherboard: ABit AB-BE6-II Intel 440BX
HDD: C, D - IDE 1, CD-ROM - IDE 2, E - IDE 3
