First post, by veso266
Hi there, I found a stash of theese behind the dumpster (which is wierd, I thought that we are at least 10years behind floppy disks are wortless, lets get rid of them phase)
https://imgbox.com/g/1rkFzRUKiH
As u can see they are dirty, they are wet, water got everywhere
Now how would I go cleaning them, since they are in hard plastic shell, I would think they would be somewhat protected
I dont care if I get any data off them (right now I am afraid to even try to read them), since its probably, just random users junk (documents, pictures, etc), but I would like to use them again, to put new data on them, since u cant get floppy disks behind every corner like u used to
I did manage to dry them and clean the shell: https://images2.imgbox.com/f1/f8/xBseUAXu_o.jpg
But not sure if its enough
I cant even found any open hardware floppy disks online, you only get floppy emulators
Shell could be 3d printed, the little spring that holds the door closed, could be made
The onlything I am not sure is, how to make the disk itself. with what material to coat it (the disk looks to be coated plastic)
I mean, people do homemade LCDs, nixie tubes, valves, etc, but nobody does floppy disks seams to be even easier, since u just have to coat evenly something with something
Reply 1 of 5, by the3dfxdude
Disks exposed to the weather like that and attempted to be cleaned should be considered single use if you were trying to recover the files. Since you don't care about the files I would not use those disks in any drive. It's not worth the hassle and potential damage.
If you want to make floppies, then you probably want to find the machine(s) used to make them. They are probably still around somewhere, but good luck. Making a floppy is a known science, but you'll probably want a machine to get good results, and not sure if it would be easy to create something yourself.
Reply 2 of 5, by Jo22
Oh well, can this be done, at all? 🙁
I'm just a layman, of course, but my first thought was cleaning them with purified water.
An ultrasonic washing device might get dust/remaining particless off, too, maybe?
Anyone else having ideas, please? 🥺
Reply 3 of 5, by nhattu1986
from my experience with cheap floppy disk after soaking in the rain,
when the water is inside the disk, it will break the magnetic layer and the disk is no longer readable.
Reply 4 of 5, by wbahnassi
I assume you're doing this for fun, as floppy disks are still possible to find in local selling groups.
You can remove the metal door and the spring, then carefully slide a knife near each of the upper two corners and twist it gently until the two shell halves separate with a crack sound. There are plastic posts that will break, but can be easily glued back again once you're done cleaning the disk.
With the shell open, you can wash the both the shell and the media. Tap the media gently with a tissue to dry it, and ensure the shell's inner cleaning layer is also dry before putting everything back together.
Turbo XT 12MHz, 8-bit VGA, Dual 360K drives
Intel 386 DX-33, Speedstar 24X, SB 1.5, 1x CD
Intel 486 DX2-66, CL5428 VLB, SBPro 2, 2x CD
Intel Pentium 90, Matrox Millenium 2, SB16, 4x CD
HP Z400, Xeon 3.46GHz, YMF-744, Voodoo3, RTX2080Ti
Reply 5 of 5, by the3dfxdude
Jo22 wrote on 2024-11-21, 14:55:
The only people I hear do it are data recovery people. Very few spend the time and have done data recovery successfully. And expect that the disk is essentially "destroyed" after it is attempted and need to clean your drive heads after it.
