First post, by DustyShinigami
- l33t
Hi
I did notice a peculiar issue with Broken Sword 1, which I mentioned in another thread, and I may have found a possible link. The issue involves a flickering mouse cursor in the game, and I’ve noticed in some situations the animations flickering as well. I believe someone mentioned this, or something similar, in another thread where they tried to play the game through DOSBox.
I thought changing the GPU drivers would help, but it hasn’t. However, looking under DxDiag, and performing a DirectDraw test, I did notice when it does it in full screen, the bouncing cube flickers. So I figure the issue is tied to that. I did see somewhere else on the system that its version is 1.0.
Now, can this version be updated at all? Or, is it possible to somehow downgrade the DirectX version? It was using 6 originally, but I ended up installing 9.0c, and this has left me with flickering 2D graphics it seems.
Thanks
OS: Windows 98 SE
CPU: Slot 1 Pentium III Coppermine 933MHz (SL448)
RAM: Kingston 256MB 133MHz
GPU: Nvidia 16MB Riva TNT/128MB Geforce 4 Ti 4200
Motherboard: ABit AB-BE6-II Intel 440BX
Sound Card: Sound Blaster Live Value CT4670
