First post, by Glaurung
For multi booting, rather than mucking around with bootsect.dos and boot.ini and so on, I thought I'd just create multiple primary partitions and switch the active partition from one to the other. I have the partitions created and OS's installed, and there's no problem with switching between them using Fdisk/diskpart. But I vaguely remember having a program that let me do this without having to manually set the active partition each time at the command line, 20+ years ago (it might have come with partition magic? I can't recall).
Unfortunately, Google is being useless for finding such a utility today. Is there such a tool, that will work for both 9x and XP/later versions, and that I won't have to pay for?
