chinny22 wrote on 2024-10-13, 23:50:
Maybe follow this guide?
Bouns is it'll install less bloat then the default creative ones as well
[OUTDATED] Installing Windows 9x and DOS drivers on Sound Blaster Live! cards (version 3.1)
TY, but this guide is not for Windows 2000, it's for Windows 9x (and it's recommended to use VxD architecture drivers there, but Win2K uses WDM) and DOS (which Win2K doesn't technically have).
Joseph_Joestar wrote on 2024-10-14, 01:34:
My advice is to try the official driver CD for the card, but even that might be too new since the SB0060 came out in September of 2000. It was the first SBLive 5.1 model, and those use newer drivers than the older versions of that card. The SB0100 and SB0220 came out even later.
I've tried so many, I found only one that at least gave me the sound via manual driver install, but not the Creative software. I explain more in the end of the post.
Repo Man11 wrote on 2024-10-14, 02:36:
KT7A guy was kind enough to upload the driver disk for the SB0220. That's a good card for Win9X but it can be difficult to find the VXD driver for it, so the beauty of that download is that it has those drivers and even instructions. Hopefully the Windows 2000 driver will work. I just set up a Socket 370 system with Windows 2000 and (to my pleasant surprise) Windows 2000 with SP4 had a native driver for my SB Live! CT 4670.
http://vogonsdrivers.com/getfile.php?fileid=8 … menustate=43,36
I've just tried it, the result is the same - it hangs at some point. I've even tried the pack, recommended by KT7AGuy for W2K/XP, the LiveDrvUni-Pack(ENG).exe, the installer hangs too, pretty fast, but it manages to do something, because I get "PfModNT.sys couldn't be loaded" on reboot. When I try to install the drivers manually, Windows hangs installing "Creative EMU10K1 Audio Processor (WDM)".
leileilol wrote on 2024-10-14, 04:34:
CallMeRive wrote on 2024-10-12, 19:36:
(I thought Win2000 would be easier and from there I'd go to Win98 and DOS...)
It's anything but. NTVDM is terrible at dos game compatibility and there are Win95-98 games too stubborn to behave on NT kernels (or support them, as there was a time when NT4 couldn't have a newer enough DirectX). Win2000 had more of a place for enthusiasts on much faster machines (~500-1000MHz) wanting to play then-current (i.e. 2000+) new Windows games with more stability.
Well, I'm not stupid enough to run DOS games in W2K. 😀 I want is as a base stable system for the machine to be able to manipulate partitions and files of other systems and with possibility to run compatible games. I do remember using Windows 2000 almost exclusively in 2001-2002 and back then it felt very stable compared to Windows 98, especially for gaming. Actually, it feels OK even now on this Pentium, I have modern laptops that barely can run W10 at the same perceived speed. 😀
Also a Live's a major mismatch for a P166MMX anyway. Live expects much faster (to put it in perspective, the Live 5.1 came out mere months prior to the Pentium 4 launch). The FM emulation TSR will choke the CPU on DOS games. When the P166MMX came about, Creative's big card was the ISA Sound Blaster AWE64 Gold, and PCI sound cards were barely around the corner....
That's a very good point. I remember having a Live! card at some point, but probably it was after my Pentium MMX back then.
AWE64 Gold and some other variants cost an arm and a leg here. For example, I got these SBs as junk in a natural supermarket plastic bag, smelling of weed, full of cables, old memory and coolers, all for $10, so that's my level of budget. 😀 I might be able to find a Value version, like CT4520, for $30 and then later, if I feel like it, I could get some custom memory for it... This is something to think about, TY!
So, about the WORKING drivers. The only package that at least gave me sound so far has been "Sound Blaster Live! Install (VXD 4.12.01.0905 + WDM) Retail CD" (http://vogonsdrivers.com/getfile.php?fileid=805). Again, not a single installer works there, but at least the drivers can be instlled manually, from the Wdmdrv folder. Interesting that it installs the "Creative SB Live! Series(WDM)" driver and it's unsigned and doesn't display its info properly.
There is an even older one, from 2000, it's only for SB0060 of all my cards, but it's worth a try.
