Thinning solder mask?
First post, by Shponglefan
Does anyone know if it's possible to thin solder mask and if so, what substance might be best for that?
I was reading about substances to thin nail polish and have seen suggestions including acetone and mineral spirits. I'm wondering if the same could be done with solder mask.
I'm especially curious to see if it could be thinned enough to apply it via airbrushing.
Pentium 4 Multi-OS Build
486 DX-33 with 5 sound cards
Reply 1 of 4, by paradigital
Interesting, I’ve got some conformal coating and some cellulose thinners along with an R/C car painting airbrush. I could be tempted to try this.
Reply 2 of 4, by wierd_w
Cheap solder mask is just epoxy with green alcohol dye in it.
As such, xylene would thin it fantastically.
It this is a fancier UV curing resin type instead, more sophisticated chemistry that is resin specific may be required.
Reply 3 of 4, by Shponglefan
wierd_w wrote on 2024-11-26, 17:56:
What I have is the fancier UV curing kind.
At any rate, I might do some experiments with a few different chemicals to see what works and what doesn't. Should be easy enough to figure out.
Reply 4 of 4, by wierd_w
Thin with the xylene, spray, then outgas in a vacuum pot/chamber.
Then cure?
