First post, by Babasha
Hi!
I receive Radysys PIC-3 4900 arcade/slot machine motherboard based on 486 CPU in "industrial" format.
The attachment IMG_1634.jpeg is no longer available
And with two additional compactflash 64MB cards
The attachment IMG_1635.jpeg is no longer available
Download chipset Radysys R400EX techspecs and will try to reanimate it with conversion to "usual" PC
Sadly all connectors are in propiertal format (except one MOLEX connector). As i understand MS/KBD (10 pin connector is PS/2 mouse/keyboard) can be invistigated by 5V and GND lines. VGA (10 pin connector) can be invistigated by CIRRUS LOGIC standard diagram (all RGB signals already visible and should find other VGA sync and GND signals).
Maybe someone already got the schematics or additional info for connectors or jumpers of such card? And utilities for later reformat of onboard 16MB flash disk and CF cards?
Need help? Begin with photo and model of your hardware 😉
Reply 1 of 2, by rasz_pl
Your post reminded me I have ancient National/AMD Geode based Set Top Box stashed somewhere. Hopefully your progress will motivate me to dig it up and have a play with mine.
Reply 2 of 2, by Babasha
rasz_pl wrote on 2024-11-27, 02:39:
Just for memo. Will continue investigation later.
