First post, by marcushg85
After the successful repair of a 5150 and an original CGA card, came a 5160 board (bought it as removed from a working computer but being stored in the cold for years...) and surprise but it doesn't work, no beeps, nothing. Here's a list of all what I've done:
5160 motherboard diagnose.
Checking with a generic AT psu
Replaced most prone to failure tantalum caps with some low ESR electrolytic caps (until new tantalums arrive)
Reflown the solder in many main ICs
Diagnostics card doesn't show any numbers, all lights power on except reset (powers on most instantly) on
CPU pin 22 on boot 4.5v. also tested good replacements
8284 chip tested replacement and in another board ok
8284 chip clk signal 0.55v ????
8284 chip reset goes high 5.3v and stays high
8288 chip had some marks of paint so replaced it for a new one just in case. Replacement has a different name sab8288ap instead of the sab8288p (is there any difference?)
Tested all Ram chips and they're ok
Tested the CPU ok
Tested the ROM chips and ok
Replaced 14.318 crystal
Replaced C1 for a 22pf cap
Replaced C-55 with 47nf ceramic cap
Tried to add load to PSU with hdd
All tests without the CGA card or anything else other than the test card and pc speaker
Upon visual inspection I see that AMD IC with some strange discoloration..
Other than that the board is visually perfect.
Let's see if someone can point me into the right direction. Thanks
Reply 1 of 4, by Tomek TRV
As far as I know PC XT will not show any codes on a post card. I would Just install graphic card and turn on this computer.
Reply 2 of 4, by marcushg85
I forgot to mention that I have another 5160 working board and all readings voltages etc are just the same. And I have a 5150 too and both do show some codes on the test card while booting up even they might not make too much sense.
Redid the measuring on the 8284:
(I guess that 5.3 was 5.13 and was just a mistake when writing it down)
8284 vcc to gnd 5.13v
8284 osc to gnd 0.96v
8284 clk to gnd 0.64v
8284 reset to gnd 0.17v
8284 Res to gnd 5.14v
Reply 3 of 4, by Horun
Long ago had one, a 5160 - 640k board. It developed issues and was the dip switches were corroded internally, used some "tv tuner" cleaner and fixed it but was only a temp fix.
Being that the board plays totally dead is probably is something else but cant hurt to try....
Reply 4 of 4, by marcushg85
Horun wrote on 2024-11-27, 05:04:
That was one of my guesses and did also try to clean them thoroughly and flick them back and forth few times .. still the board was looking extremely clean for it's age, no dust or any traces of corrosion anywhere.. but it could still be that. Unfortunately I don't have any replacement for that and don't know how to measure them (thought it was spdt but they only have two legs)
