Tool for checking component’s health?
First post, by DustyShinigami
Hi
Does anyone know of any software I could use to check the health of components? Whilst trying to install a DirectX version, a whirring sound suddenly stopped inside the case, which I figured was either the CPU fan or the HDD. It was the HDD. I had to reboot and back on the desktop I got a blue screen error saying it was unable to read or write to the C drive. Everything’s fine again at the moment, and it may have just been a one off, but I suspect this could be the start. 😕
The HDD was bought second hand off eBay, so anything is possible. Or could it be that the PSU is starting to struggle…? Either way, I’d love to find out the overall health/life-span left of things, if that’s possible?
Thanks
OS: Windows 98 SE
CPU: Slot 1 Pentium III Coppermine 933MHz (SL448)
RAM: Kingston 256MB 133MHz
GPU: Nvidia 16MB Riva TNT
Motherboard: ABit AB-BE6-II Intel 440BX
HDD: 30GB - IDE 3; 40GB - IDE 3; 80GB - IDE 4
Reply 1 of 39, by BitWrangler
yes but also no... you can get a SMART tool to read HDD "health" data, but if it reads perfect it could still die tomorrow and if it looks awful it could still last for 15 years.
Also fans and things rely on SMBUS being included on the motherboard, basically PIII era upward, and having the 3rd wire for speed monitoring. Then you can use utils to determine if a fan is not running full speed etc, and if voltages are alright. Older hardware, nope, gotta break out the multimeter.
Reply 2 of 39, by DustyShinigami
BitWrangler wrote on 2024-11-28, 19:12:
Ahh, I see. That’s unfortunate. 😕 I’ve yet to invest in a multimeter, though that would be to check the voltage to find out if I can upgrade to Coppermine.
OS: Windows 98 SE
Reply 3 of 39, by Horun
My experience with CrystalDisk and "smart" HD's is that if they show green for a while and then one suddenly shows yellow, the drive will die in days to months, but the death is coming.
Have never had one show green suddenly die, always it goes yellow just before death (usually retries, allocations error, etc).... I check my drives weekly now. This is only my experience with the tool.
Reply 4 of 39, by BitWrangler
Yeah it's the change that mostly tells you anything, monitor for 6 months, get one more bad sector, no biggie, monitor after 6 hours and get one more bad sector, and another in another 6 hours, backup, she's going south.
Reply 5 of 39, by DustyShinigami
Horun wrote on 2024-11-29, 02:34:
CrystalDisk. Cool. And I was sorting of hoping for a tool that shows you a component’s health with colour. I’ll look into it. Thank you. 😀
OS: Windows 98 SE
Reply 6 of 39, by soggi
There are some good HDD tools for Windows - the ones I use(d) are HD Tune 2.55 (free version, Win2k+, https://www.hdtune.com/), SpeedFan (just S.M.A.R.T. values, Win9x+, https://soggi.org/misc/tools.htm), TesDisk (partition repair and stuff, many OSes, FOSS, https://www.cgsecurity.org/).
kind regards
soggi
Vintage BIOSes, firmware, drivers, tools, manuals and (3dfx) game patches -> soggi's BIOS & Firmware Page
soggi.org on Twitter - inactive at the moment
Reply 7 of 39, by ElectroSoldier
I wouldnt trust SMART as it is as the guys said above, once it shows a warning of any kind of moribund. In your case its already failed so yes it will fail sooner rather than later.
Time to get a "new" one.
Reply 8 of 39, by soggi
So what's your alternative for S.M.A.R.T. values - asking the HDD god if the HDD has good karma or time traveling to the future returning with the knowledge of what will happen?
The values are no forecast, no tool says that the HDD will be broken in x seconds, it's all about probabilities (not about trust) and the user has to interpret on his own what the best choice could be...
kind regards
soggi
Reply 10 of 39, by ElectroSoldier
soggi wrote on 2024-11-29, 07:38:
So what's your alternative for S.M.A.R.T. values - asking the HDD god if the HDD has good karma or time traveling to the future […]
kind regards
soggi
Why would you need an alternative?
When you use a drive you keep backups. When it fails you restore.
It really is that simple.
Then it doesnt matter if SMART works or if it doesnt does it?
Reply 11 of 39, by soggi
DudeFace wrote on 2024-11-29, 17:50:
HDTune Pro is the only way to go when it comes to HDD/SDD's, i used to work for a company building systems that used it, thats when i first found out about it, brilliant program. read my post here with picture
Re: Windows XP: "Please insert the disc: 1" error during installation
That can also be done with the free non-Pro version - the only problem is that the latest version is from 2008, so it misses support for newer HDDs and especially SSDs.
ElectroSoldier wrote on 2024-11-29, 23:46:
Because that was the question! The TO asked for tools to check component's health, he didn't ask for Backup software. To quote you: "It really is that simple."
It is correct that it's a good idea to have a backup but this isn't the topic here.
kind regards
soggi
Reply 12 of 39, by ElectroSoldier
soggi wrote on 2024-11-30, 03:27:
That can also be done with the free non-Pro version - the only problem is that the latest version is from 2008, so it misses sup […]
kind regards
soggi
You dont need an alternative to it, you use it like I said.
It tells you when its moribund. Its at that point you buy a replacement.
Simple really.
No replacement required.
Reply 13 of 39, by soggi
No, you're on the wrong topic.
kind regards
soggi
Reply 14 of 39, by DustyShinigami
Marvelous. Just before I got chance to try Crystal Disk, the HDD is acting up again. This time, it's getting worse. It keeps trying to 'rev up' and struggles. Before I had to force it to shut down, the fan/sound of it completely died out again. Just to make sure the PSU isn't the cause, I'll have to try disconnecting my D drive and see what happens.
OS: Windows 98 SE
Reply 16 of 39, by DustyShinigami
Shponglefan wrote on 2024-11-30, 16:50:
You might want to consider switching to an SSD. Any mechanical hard drive, especially a used one, is going to be a gamble.
Is an SSD even going to work in my system? Or is there some wizardry that can get them to work with IDE cables etc? Surely it would be crazy fast for a lot of things in Windows 98? 😅
OS: Windows 98 SE
Reply 17 of 39, by DustyShinigami
Disconnected the D drive, which was originally the C drive when I bought it, and apart from some slow response times at loading Explorer, everything seems fine. No crashes or fans stopping. I ran through Crystal Disk Mark 2.2 and these are the results:
The attachment IMG_3832-compressed.jpeg is no longer available
OS: Windows 98 SE
Reply 18 of 39, by Shponglefan
DustyShinigami wrote on 2024-11-30, 17:04:
You can get IDE-to-SATA adapters: https://www.amazon.com/StarTech-com-Drive-Opt … r/dp/B00EOJNGC2
It won't be crazy fast. You're still limited by the IDE bus.
Pentium 4 Multi-OS Build
486 DX-33 with 5 sound cards
Reply 19 of 39, by DustyShinigami
Shponglefan wrote on 2024-11-30, 17:17:
Oh, awesome. Definitely something I’ll have to look into at some point. Thanks for sharing. 😄
OS: Windows 98 SE
