First post, by zuldan
- Oldbie
I managed to get one of these boards. Getting 17Fps in Quake so very happy. I wish to use a 10Gb PATA drive with the board and run Windows 95. I guess I have two options:
1) Install an IDE Controller
2) Upgrade the to the Award BIOS (2A4X5H21 - Newer AWARD Bios for HOT-433?)
3) Use XTIDE https://youtu.be/ofZLDAOmZYU?si=y2qfYnzePV8EiQVO
Couple of questions:
1. I have a Promise Ultra66 (using latest v2.00 firmware). It appears to work fine (detects the CF card correctly) but I can’t get it to boot to my CF Card (onboard IDE Controller is disabled and 33MHz PCI bus). The CF card is 4GB but formatted to 2GB and boots fine from the onboard IDE controller. I haven’t tried to boot from the 10Gb PATA drive yet. I read here My 486 UMC8886/8881 Project (Version 2.0) the board is very picky about IDE Controllers so maybe this isn’t an option unless I grab a HighPoint controller (which will boot?).
2) I read somewhere a lot of things don’t work with Rev 4 with the Award BIOS like the FDC (not sure why it’s listed on TRW if it wasn’t for Rev 4?). Will my COM ports work? I can live without a FDC but not a serial mouse (maybe a work around is to get a PicoGUS and use a USB mouse). I think I’m running the latest AMI BIOS but the BIOS post string has “-H” tagged on the end?
