chinny22 wrote on 2024-12-06, 00:03:
I'm allowed to grab a "reasonable amount" but any reason not to just get the larger drives?
I've got a source for as many "spinning rust" drives as I want, and I usually prefer smaller ones. (100-500g is my preferred size range)
I usually use these drives while testing various things, and I find that is almost always LOTS for anything I'm not planing to put into long-term use.
I mainly choose smaller as I'm often testing older stuff and some systems either don't accept, or can get noticeably sluggish with very large drives.
and ... if it's a different file system, or the OS just "wants" to as part of it's install, it can result in a full-format which for some systems can take a long time on big drives..
And don't forget - loosing 1 of an array of 4 500G drives instead of losing 1 of an array of 1 2T drive does mean you have a better chance of not losing all your critical "stuff" - and yes.. you should keep it backed up .... but how often do you backup 2T of data. (if you can get enough of the bigger ones,
consider RAIDing them)
Dave ::: https://dunfield.themindfactory.com ::: "Daves Old Computers"->Personal
https://dunfield.themindfactory.com ; "Daves Old Computers" ; SW dev addict best known:
ImageDisk: rd/wr ANY floppy PChw can ; Micro-C: compiler for DOS+ManySmallCPU ; DDLINK: simple/small filetransfer(w/o netSW)via Lan/Lpt/Com
