First post, by Dan9550
- Newbie
I'm wondering if anyone who has a bit more experience in this realm can shed some light on my experiences so far using modems for multiplayer gaming.
I have two identical machines setup one with a USR 56K USB Modem and the other with a USR 56K Message Modem. The modems are connected to each other through a Cisco ATA (SPA112) with a dial plan setup so the two lines can call each other. Options like fax and echo cancellation on the ATA have been switched off.
I can dial from one modem to the other, answer and establish a connection, woohoo!
But I've tried a few games with varying success some work, others don't overall it feels pretty sluggish not exactly what I'd assume is correct but I wouldn't really know never did this back in the day.
Age of Empires - Works, some lag to start a game but other than a bit of latency seems fine.
Tiberian Sun - Same as Age of Empires maybe a bit slower overall like you can feel it syncing one end to the other.
Heroes of Might and Magic - Fine, had to tell of there are any issues since its turn based.
These games I'm running in DOSBox-X passing through the COM ports directly.
Warcraft - Sluggish, very much so in the menus.
Duke Nukem 3D - Never finds the other player.
All of these games work fine over LAN or direct serial wondering if there is some tweaking that can be done modem side to improve things or is the ADC - DAC being done by the ATA taking more out of the connection than it seems. USB modem causing issues perhaps?
Keen on some opinions from those of you that did this back in the day or have experience with a similar type of setup as I have.
