First post, by Major Jackyl
- Member
Alrighty! Time for a good PC building story! I went to the computer thrift store this weekend, to look for junk to fix and BEHOLD! I did find junk, 🤣 The junk in question was a Gateway 2000 P5-200 Tower with a very attractive "$5" sticker on it. Closer inspection revealed the sad-shape this thing was in. Sticker(s) said "No CPU, No Mem, NO HDD" No NOTHING. PSU in there and the board (and a bunch of broken plastic bits). Heh, for five bucks, can't go wrong with the hours of fun that may ensue, so I grabbed it.
I got it home and it already fell apart in the car. All the plastic for holding on the face was broken including pieces holding sub-pieces for the face. Very yellow as well. A bit of an odor on that, too. I removed EVERY screw and added them to the collection and removed the board. Setting the case aside, I inspect the board. A bit dusty, but no bad pins, etc, so I cleaned the whole board with contact cleaner/air and let it chill. I want to test it, so I started digging about for some parts.
I enjoy building and disassembling, so I went straight for a "new" case. The case I went with is an A-Open Flat-type desktop case. The first issue I ran into was as soon as I lifted the motherboard in: standoffs. The standoffs in the case are VERY unusual height (very tall) and I couldn't find ANYTHING to add any, so I had to move the ones there around (10-hole board) and now the board is held in with 6 screws. Next issue, was the IO panel. It was a flat metal piece designed for a special square bracket, etc, etc, Easy enough workaround: print a new one. I cleaned the rest of the parts while waiting for that and found a suitable heatsink for Socket 7 as well. When the panel finished, I installed it, the board, and the PSU. Almost a whole computer again. With the board in, I dug out my socket 7 CPUs and checked pins. I have 2 Pentium SY022 (133MHZ) and 3 Pentium MMX SL25N, SL26J, and SL27J (all 200MHZ). I only have two 32MB modules(known good), which is all the board can take, I believe. The rest are all known good parts: Cirrus Logic VGA, 3COM ethernet, and SB16Valu.
I assembled the minimum (MEM, CPU, Video) and started the testing. First up was the SY022, which is what I wanted to have in here. Power cord - computer comes on... Nothing. No beeps. I yoink the heatsink and the CPU is getting VERY hot. Hmmm. Don't like that. I tried SY022#2. Power cord - Computer comes on... BEEP.... BEEP...BEEP. Three Long Beeps and then nothing. CPU not getting hot this time. I pulled the mem, checked again, same. Well damn. At least it's powering on, right? I removed the CPU again and powered it on empty (no RAM, CPU) and it does what you'd expect. Powers on and does nothing. I put the RAM back in and tried SL25N. Power cord - Computer comes on... beep, beep, beep. Three short beeps now. Which I believe is memory errors, so I tried reseating and other modules (which I knew may not work, too new), but the 3 short beeps persist.
I have it fully assembled (to save space)now, but non-functional.
Since then, I opened my computer (the one the 32MB modules were original to) and tested the 32MB modules again. Good.
I've also tried powering it on with and without memory, video card (none of the other cards were in for testing).
If I wait to find other memory modules, I might be waiting a while...
Is there anything else I can do with the parts/tools on hand? I don't have a diagnostic card, but I have scope and multimeter(s). I would like to confirm diagnosis before hunting parts.
I don't feel safe to assume the SY022s are bad yet, I would like to test in a board that booted already before writing them off. The hot one, might be done, though...
All 3 MMXs that I have yield the same result (3 short beeps). Only one was "known good" and I'm assuming the similar behavior means they are all good.
I only have one PCI video card to test with as well.
Daily Units:
ASUS P55TVP4, P-MMX233, Matrox2064W, CT2770
ABIT IS7, P43.2(SL7E6), PNY6600GTS, Audigy(0090)
ASUS M2N-SLI, A64X2-5600+, EVGA 8600GTx2, Audigy2(0240)
ASUS ST-990FX, FX-8350, MSI GTX760x2, SB X-Fi(0460)
MSI Z690, i9-12900K, MSI RTX3090, SB AE-7
