Reply 55460 of 57622, by Shadzilla
- Member
I picked this up on Wednesday because it's the same case as the PC my family bought in 1997 from Tiny here in the UK. They seem to be quite hard to find now? It doesn't help that searching for 'tiny pc' gets you completely useless results! Ours was AT and S7 P200, this one is ATX and contains MSI MS-6119 board, PIII 450, 384MB ram, 6GB and 12GB HDDs, Geforce 4 MX 420, a Yamaha sound card, a modem, and a wifi card. The optical drive doesn't read discs. I'm assuming the ram has been upgraded from a 128MB base, the 12GB HDD added (the one floating around...), graphics card changed, and wifi card added. The chassis and 6GB drive are dated March 1999.
Amazingly though I just cleaned it out and it fired right up and booted into a WinXP install.
I'll retrobrite the front panel in the spring when the sun reappears and then set about building a replica of our old Socket 7 PC in it 😀
in box with manual and accessories. Apparantly a drop-in IDE mirror solution, which is quite interesting!
Supermidro P6SBU sealed with box, manual, accessories.
Nice motherboard. Integerated Yamaha general midi, OPL3-SA/OPL4, and S3 video.
interested CPU package, haven't owned one of those before
