First post, by MarmotaArmy
Hello,
I'm about to adapt and live with this issue but maybe there is some useful idea from you guys to try. This place is where knowledge is
-I bought a few weeks ago a PC with a FIC PVT-486 motherboard and a 520mb hard drive
-Wanted to have more space so I got a 2gb CF from ALI ,and a CF adapter with bracket
-I was doing disk cloning using norton ghost, computer open keyboard on top. Time for supper.
-Came back and the computer was off. What?... didn't want to turn back on... panic
-I disconected everthing waited a few minutes and could power it on, but the 2 gb cf was dead. Well i had another 8gb cf , a waste but whatever.
-The autotdetect feature detected both the HDD and the CF , all good, but after exiting bios menu in the bios boot secuence I got Hard disk fail error (80) and after pressing f1 couldn't boot into DOS
- But if I removed the CF card no problem whatsoever. Working in DOS
- Tried with HDD and another CF and from a working 386 same problem
- Tried with both CF from the working 386 same problem
- Tried with only one CF and no HDD and no problem
- Tried with 2 HDD and same problem
- Did the same tests with another ISA controller, same behavior. for now I'm using a PT-606G controller.
So now it only works with one hard drive connected but if I plug a second one (CF or HDD) the system will do the memory test , throw a Hard disk fail error (80) and wont' boot.
Any idead of what could it be? a condenser somewhere? , damaged bios ?
