First post, by asdf53
Socket A systems have a reputation as power hogs, but what about newer motherboards that can manipulate clock speed and voltages? Does it help or will the CPU fail to work at the slightest undervolt? I connected an ampere meter to the PSU to measure total power consumption of the system and did some testing.
System: MSI K7N2 Delta-L (nForce2), Athlon XP 2700+ (Thoroughbred), Geforce 2 MX, 400W IT-Power PSU
I started with a clock speed of 1950 MHz and gradually decreased the core voltage to see how it impacts the power consumption. For testing I used prime95 to get the CPU to 100% load.
1950 MHz @ 1.65v: 132w load / 94w idle
1950 MHz @ 1.6v: 124w / 89w
1950 MHz @ 1.55v: 119w / 85w
1950 MHz @ 1.50v: 116w / 83w
1950 MHz @ 1.42v: 107w / 79w
1950 MHz @ 1.3v: fails to POST
Now for the most interesting part: What is the lowest power consumption we can achieve? I set the clock speed and core voltage to the lowest values that the board supports:
700 MHz @ 1.3v: 70w / 61w
Then I tried to find the sweet spot, the highest clock speed that's still stable at the lowest voltage of 1.3v:
1750 MHz @ 1.3v: 86w / 63w
That's 200 MHz slower than my usual system, but draws 46w / 31w less power. That's pretty good! What are some of your results? Does anyone have a board that can go lower than 1.3v?
Reply 1 of 10, by mkarcher
To get the idle consumption down, research for tools enabling the stop-grant mode of the CPU/chipset, and check whether they work on your board. Possibly you can even find an option to enable stop-grant mode operation (allows the processor to disconnect the FSB and put itself into a static low-power sleep mode) in your CMOS setup. On a cursory research, s2kctl seems to be a tool supporting the nForce2, but nForce2 boards often have problems properly working with the stop-grant mode, but it's worth a try.
Reply 2 of 10, by asdf53
mkarcher wrote on 2022-10-16, 14:21:
Thanks, I didn't know about this. I have Windows 98 installed so I cannot test it right now, the patch only works with Windows XP. I will install it later and report back!
Reply 3 of 10, by asdf53
Wait, s2kctl does work under Windows 98! I had to use a slightly older version. After enabling the halt state and clicking apply, idle consumption dropped from 79w to 60w. That's so cool. How is this so little known?
Here's a link to the author's website of s2kctl: https://web.archive.org/web/20070104164612/ht … targaz0r.nm.ru/
And the version that I used is "s2kctl14b72.zip". Other versions crashed on startup.
I have now installed a Geforce 7600 GT and CPU is at 1800 MHz. Idle: 59w, gaming: 83w. The CPU fan is barely spinning in idle mode. That's really impressive for a powerful Socket A system.
Reply 4 of 10, by mkarcher
Be aware for side effects, though. On my ECS K7S5A (yeah, I know, not the most highly regarded Socket A board, even though it has its cool black PCB), the hard drive performance on an otherwise idle system dropped from like 50MB/s to 5MB/s on enabling stop-grant mode. Probably because the south bridge needed to wake up the CPU for every couple of bytes read from the hard drive. If you don't notice any problems, though, keeping stop-grant mode enabled doesn't hurt your system.
Actually, it was quite well-known (at least in Germany) back in the days, tools like VCool for VIA chipsets were oftentimes used by PC enthusiasts in the early 2000 years to lower idle power and noise.
Reply 5 of 10, by Linoleum
... speaking of Vcool, is there a link for the latest version (2.0) still active somewhere? I could only find v 1.8 (beta) on MajorGeeks: https://www.majorgeeks.com/files/details/vcool.html
P3 866, V3, SB Audigy2
P2 400, TNT, V2, SB Audigy2 ZS
P233 MMX, Mystique220, V1, AWE64
P166, S3 Virge DX, SB32, PicoGus
486DX2 66, CL-GD5424, SB32, SC55
Prolinea 4/50, ET4000, SB16
SC386SX 25, TVGA8900D, Audician32
286 10, ATI VGA Basic, Forte16
Reply 6 of 10, by asdf53
Linoleum wrote on 2024-12-19, 16:29:
Found it here: https://www.softking.com.tw/dl/13286/VC ... 2%BB).html
https://dl.softking.tw/9a64726332bb7fbe845894 … ool_alpha_6.zip
But please virus check it, I have no idea how reputable that site is.
Reply 7 of 10, by Carrera
mkarcher wrote on 2022-10-16, 18:05:
I LOVED Vcool back in the day...
Reply 8 of 10, by analog_programmer
Mobile Athlon XP CPUs (Athlon XP-M) do support PowerNow! dynamic frequency scaling and power saving technology. I don't remember if there was "pencil mod" for turning Athlon XP into XP-M and if there was any s.A desktop motherboard that was able to use the mobile Athlon XP-M CPUs. It would be great if it is possible to use these mobile CPU power saving functions on a desktop system.
The word Idiot refers to a person with many ideas, especially stupid and harmful ideas.
This world goes south since everything's run by financiers and economists.
This isn't voice chat, yet some people overusing online communications talk and hear voices.
Reply 9 of 10, by asdf53
analog_programmer wrote on 2024-12-20, 11:59:
It's been a long time since I used my Athlon XP machine (this thread is old!), but I believe you could turn any Athlon XP into a mobile CPU by cutting or connecting some bridges, except the ones with Barton core after a certain manufacturing date, those were finally made tamper-proof by AMD. This would at least allow you to change the multiplier, but it won't give you the better silicon that real XP-M's had which allowed them to run at much lower voltages. I believe the XP-M's worked in a lot of (or all?) desktop boards, but to use the dynamic power saving features, you also need a compatible motherboard and vendor-made driver for it, the CPU won't do the throttling on its own. Desktop boards didn't have that, so this feature was only available on laptop mothboards.
As for regular desktop boards, you can only set a fixed voltage, and only few motherboards allow you to set very low voltages through the BIOS. I know of one motherboard that lets you use any voltage, even the lowest supported ones: https://theretroweb.com/motherboards/s/qdi-k7 … -k7e-kinetiz-7e
It doesn't set the core voltage in the BIOS, instead it has old-fashioned jumpers that directly manipulate the L7 bridges of the CPU. The lowest voltage that can be set using these bridges is 1.15V, I believe. I tried to boot an Athlon XP at that voltage and a speed of around 1000 MHz, and it worked. So that's another option for an ultra low-power XP machine.
Reply 10 of 10, by bakemono
CrystalCPUID can be setup to do automatic throttling on XP-M CPUs. The voltage adjustment only works if supported by the motherboard. If not, it can change the CPU multiplier only. Desktop and mobile Athlons both have designated pins for indicating to the board which voltage should be used. The issue is they use two different incompatible schemes, and desktop boards mostly only support the narrower range of voltages specified by desktop CPUs.
GBAJAM 2024 submission on itch: https://90soft90.itch.io/wreckage
