First post, by KainXVIII
I can't use mouse in main menu (always clips to the lift side of screen) and if you try to play actual game camera just keeps spinning (this is on dgvoodoo ver. 2.84). The only working solution that i found for now is to set scaling mode and resolution to unspecified (but this is defeats the purpose of dgvoodoo2 😅)
