VGA Capture Thread
Reply 1480 of 1534, by ruthan
Spitz wrote on 2024-10-07, 19:09:
Hi Guys. I would like to small express my experience about VGA/SVGA grabbing. After so many things I bought and tried ... And as I was starting to be rly lost I tried a solution thatbcosted me 25EUR...
And the overall quality is just superb! What is more it is grabbing even 320x200! There is no latency, no loss quality of sound or video ....
And what is the name of that magic device?
Im old goal oriented goatman, i care about facts and freedom, not about egos+prejudices. Hoarding=sickness. If you want respect, gain it by your behavior. I hate stupid SW limits, SW=virtual world, everything should be possible if you have enough raw HW.
Reply 1481 of 1534, by clb
Today I recorded an example of DOS 320x200 @ 70Hz video capture using a combo of CRT Terminator Digital VGA Feature Card ISA DV1000 and StarTech USB3HDCAP HDMI Capture Device:
- https://youtu.be/8o7cu9mYL10
- direct video download that avoids YouTube recompression: https://oummg.com/dump/commander_keen_foray_i … _terminator.mkv (this is an unconventional 70Hz video file, if you have a high refresh rate gaming display to view it)
Unfortunately USB3HDCAP is a lossy 4:2:0 Chroma capture device, so some softening is present.
The CRT Terminator user manual now contains a section to go over the video capture settings that were used.
Reply 1482 of 1534, by NightSprinter
Hmm, so it seems that some custom modes in DOS are being seen incorrectly by both Datapath cards. The fullscreen modes of the clone games PacPC2 and Ms. PacPC supposedly runs in a resolution of around 576x448p58.5, yet the capture card is reading just 640x480p59.97 and cuts off the top and bottom. Is there any way to fix this?
Reply 1483 of 1534, by clb
That sounds interesting. I took a recording of PacPC2 from my 80 MHZ Cyrix 486 PC with Cirrus Logic CL-GD5422 video card with CRT Terminator and StarTech USB HDMI Capture and OBS. It looks like the game has a separate "full screen" arcade cabinet mode, and a fallback 320x200 Mode 13h video mode.
Here is a recording of the test:
https://oummg.com/dump/PACPC2_486_Cirrus_Logic_5422.mkv
The high resolution is programmed as follows:
The attachment PACPC2-high-resolution.png is no longer available
Whereas the compatible fallback resolution is programmed as follows:
The attachment PACPC2-compatible-resolution.png is no longer available
(this is standard Mode 13h)
If your capture setup allows programming the video geometry numbers shown in the top right corner, you might be able to get a clean capture.
Reply 1484 of 1534, by NightSprinter
Sadly neither Datapath's own software, or VCS allows fine-tuning of vertical. Best I could do would be use my OSSC. Would need to swipe from living room to do so.
Reply 1485 of 1534, by NJRoadfan
I guess the Datapath cards don't support custom modes? The Epiphan cards allow tweaking the vertical.
The attachment Screenshot 2024-12-31 121144.png is no longer available
Reply 1486 of 1534, by vvbee
You had the same problem a year ago. The answer is that the VisionRGB-PRO captures the full board and the VisionRGB-E doesn't. The E isn't meant for DOS capture, but it can get by. Get a mini Windows 7 PC and put the PRO in there, good DOS capture box, if you're lucky.
Reply 1487 of 1534, by Kordanor
There just had been the announcement for a new Retrotink4k Version, which is basically a "light" version of the "normal 4k" one. For DOS capture it shouldnt make much of a difference, but its much cheaper. Old one being at 750$ and new one at 475$ (ofc you would still need an RGB capable capture card in addition to the tink).
Announcement: https://www.retrotink.com/post/holiday-2024-s … -4k-ce-and-more
image.png?ex=67757877&is=677426f7&hm=916db4f65595da0a191d6a0e7e8bcd125c235d94a5acf91f35380dede7420f9a&
Reply 1488 of 1534, by vvbee
Kordanor wrote on 2024-12-31, 18:12:
For $50 I'll consider it, if it exposes a programmable API that gives full low latency access to the frame buffer. But the fact that you need a separate capture card is a downer, if you only do VGA capture then you might as well use your PC for scaling etc.
Reply 1489 of 1534, by Hacket
I'm currently using datapath visionrgb e1s its pretty good for a grabber and streaming but has some quirks which are quite annoying. I always need to tinker with color correction because picture looks always too green and sometimes need to adjust screen size because of out of border and software forgetting settings. I wonder if there is any good alternative for this grabber i want only swap card rest of setup with direct vga/dvi connection is ok for me. I usually stream win9x and winxp machines.
Reply 1490 of 1534, by Kordanor
Hacket wrote on 2025-08-12, 09:14:
In the end it's a bit down to software, I think the hardware itself is capable to do most stuff.
The official software is rather terrible and VCS (inofficial software) is no longer developed for Windows and it's last version for PC still had a few significant bugs.
I think the only inherent issue of the visionrgb hardware is that some pixel lines on 640x480 are cut off, this can be reduced via extron rgb adsp feature but I think it was still 1 remaining line missing.
For ease of use I am now using a retrotink4k which turns the signal into hdmi and then I just capture that. However that is quite expensive.
Since I swapped my graphics card and saving into AV1, which magnifies any grain, I am now also using VCS on top of that for its amazing pixel gate, a feature which does neither exist in Retrotink4k nor in OBS. I use this for 320x200 games, and it's especially noticable if you have big sections with the same color, which without pixel gate after compression looks like a wobbling cloudy mess.
So my setup in this specific case is: PC VGA->retrotink4k-(hdmi/dvi)->Datapath(->)VCS->Window Capture in OBS
Ofc the retrotink4k isn't super useful in this context. But I don't want to switch around everything. So in this case all I do is changing software "pipeline".
Otherwise I am using PC VGA->retrotink4k-(hdmi/dvi)->Datapath(->)RGBEasy Capture in OBS
Reply 1491 of 1534, by schlang
I think I'm gonna sell my Epihphan Vga2PCIe now that I have a RetroTINK4k.
PC#1: K6-III+ 400 | 512MB | Geforce4 | Voodoo1 | SB Live | AWE64 | GUS PNP Pro
PC#2: 486DX2-66 | 64MB | Riva128 | AWE64 | GUS PNP | PAS16
PC#3: 386DX-40 | 32MB | CL-GD5434 | SB Pro | GUS MAX | PAS16
Think you know your games music? Show us: viewtopic.php?f=5&t=37532
Reply 1492 of 1534, by vvbee
Kordanor wrote on 2025-08-12, 09:28:
VCS isn't offered for any platform and won't be unless someone maintains a fork of old code. But I'd say using it is effectively unethical unless you support exploitative labor.
Reply 1493 of 1534, by maxtherabbit
🤣 what
Reply 1494 of 1534, by MaexxDesign
Hello!
I am looking for an internal capture card that supports the most common resolutions of the late 90s and early 2000s via a VGA or DVI input, such as 800 x 600, 1024 x 768, 1152 x 864 and 1280 x 1024.
So I need a capture card that natively support VGA signals such as 800 x 600, 1024 x 768, 1280 x 1024 and 1920 x 1080 at 60 Hz and a minimum color depth of 16 bits via a DVI input without upscaling because it distorts the performance of the graphics card when I record game scenes for my video projects.
I want to capture the image of a retro PC 1:1.
The monitor of my retro pc supports up to 1920 x 1080.
Can the VisionRGB-E1S do this?
I also have graphics cards that only have a VGA output.
Can I connect these graphics cards to the VisionRGB-E1S using a suitable adapter?
If so, what kind of adapter do I need?
If the VisionRGB-E1S can do that, does anyone have one for sale?
Thank you in advance for your reply.
Best regards!
Reply 1495 of 1534, by NightSprinter
For the E1S, basically you need a DVI-I/DVI-A to VGA adapter. DVI end goes into the E1S, VGA cable from adapter to PC. You'll also need to use your main motherboard's line-in for audio
Reply 1496 of 1534, by OpenRift
Hey, I'm in the market for a good MS-DOS VGA capture solution that isn't too expensive. I haven't read all 75 pages of this thread (I don't even know what I should be looking for at this point), but I've gathered some bits and pieces. The Sewell Manta and Startech VGA2HDMIPRO seem to be really solid options, but neither seem to be available for purchase anymore, new nor used. I wish the RetroTink 4K CE was something I could get, but even being the reduced cost model, $475 is still pretty steep for something I don't even know if I'll use enough.
Are there any other solid solutions that I've glossed over?
Reply 1497 of 1534, by Dusko
I have bought several vga capture cards over the last 5 years or so, including the rt4k.
2nd to the rt4k in my list is the Gefen vga to hdmi. The image quality is spectacular.
VGAAUD-2-HDMI
You want to get a remote control which has a very handy option to auto adjust the image.
Overall is the best thing I have tried besides the rt4k.
I'll check later what the remote model number is and let you know.
Retro PC games channel: http://www.youtube.com/@myRetroPC
Electronics, mods and tools channel: https://www.youtube.com/@RetroRust-75
Reddit: https://www.reddit.com/r/MyRetroPC
FaceBook: https://www.facebook.com/myretropc
Reply 1498 of 1534, by Dusko
This is the Gefen that I recommend. It's very unlikely that you'll find it with the remote, but you can find them separately in the wild (Ebay). Just be patient.
Reply 1499 of 1534, by OpenRift
Dusko wrote on 2025-08-29, 01:38:
Well luckily, I did score that model last night for a surprisingly good price. It should come in the mail next week.
