First post, by XboXC
Hi i have MB468 A1 motherboard but that motherboard doesnt have fdd controller (and no rs232, lpt ports). I plug to isa port external controller with fdd hdd and io ports. - PT 1227w v2 but the bios still get floppy C0 error
Main "PC":
Mac Pro Xeon 2x 3GHz (Quad), 12GB RAM, MacOS 10.15, Radeon HD 5770
Retro:
Apple Macintosh Quadra 650, 68040 33MHz, 64MB RAM, Mac OS 8.1
PC (clone): Intel 80486 DX2 66MHz, 64MB RAM, Windows 3.11 WfW, ATI Rage2
Reply 1 of 12, by dominusprog
The floppy drive must be set to drive-0. And what about the HDD? Is it working?
Reply 2 of 12, by XboXC
Drive-0? Motherboard have a internal hdd controller i dont tested that now but maybe they work?
Main "PC":
Retro:
Reply 3 of 12, by dominusprog
Post a photo of both the floppy drive and the I/O card.
Reply 4 of 12, by XboXC
As attachments
Main "PC":
Retro:
Reply 5 of 12, by XboXC
Oh floppy drive is standard 3.5 inch alps
Main "PC":
Retro:
Reply 6 of 12, by dominusprog
Disable the on-board IDE and try again. Also, you should mod the clock chip or add a modern clock chip like the Necroware's nwX287.
https://www.ebay.com/itm/205164925449?_skw=Ne … ABk9SR_SanbCEZQ
Reply 7 of 12, by XboXC
This clock is work (good battery). I disabled the hdd from isa. I need only fdd
Main "PC":
Retro:
Reply 8 of 12, by XboXC
Ok. When i shutdown the internal hdd controller its do nothing. I have C0 error. When i turn off floppy in bios the error doenst appear but next i stop on „disk boot failure instert disk and press enter”. Of course floppy drive do nothing
Main "PC":
Retro:
Reply 9 of 12, by dominusprog
You either have to disable the on-board IDE controller or disable the IDE portion of the I/O card.
Reply 10 of 12, by XboXC
I tried all this. First disable the hdd controller on isa card. Today i disabled hdd on motherboard but that do nothing. Bios still dont see the fdd isa controller
Main "PC":
Retro:
Reply 11 of 12, by dominusprog
Well, are you sure the card is in working condition? Have you considered buying a new floppy drive controller?
https://www.ebay.com/itm/276559002656?_skw=is … ABk9SR_j6gfmEZQ
Reply 12 of 12, by XboXC
Hmm... i will try another controller.
Main "PC":
Retro:
