First post, by HellFire376
I'm working on a retro gaming pc from around late 99 and I'm have no problems getting everything working except for the sound card, a vortex 2. In Windows 98 SE, I got the sound card working once the other day so I can confirm it's functional, but since then I haven't gotten it to work. If I use the regular vortex 2041 drivers with no modifications, while booting into windows it will say this in a DOS screen for a few seconds until booting into windows with no sound at all. Even the audio drivers without the DOS mode support do not have any sound inside windows 98. I've also tried tweaking a few BIOS settings but no luck, partially because I think I have no idea what some of these settings do. (I haven't bothered to try Windows XP since I'm aware that the driver has only basic support) Any help would be greatly appreciated!
"C:\> SET BLASTER = A220 I5 D3 T4
C:\>LH C:\WINDOWS\AU30DOS.COM
VORTEX DOS AUDIO DRIVER (2.007) Copyright (c) 1997-1999 Aureal Semiconductor
PCI AUDIO PRO enabled at Ports 220-22Fh, Interrupt 5, DMA 3, Joystick 201h.
ERROR #11: CODEC failure. Driver not loaded"
If it helps here's the specs of the machine:
Motherboard - EPOX EP-7KXA with KX133 VIA based chipset
CPU - AMD Slot A K7
GPU - Creative 3D Blaster Annihilator Pro (Geforce DDR) using Nvidia 21.83 Drivers for Win 9x
RAM - 256MB PC100
Sound Card - Aureal Vortex 2 (AU8830A2)
ofc some IDE drives and floppy drive
and eventually planning to add a Realtek 10/100 Ethernet card and an Ultra100 IDE PCI card
EDIT: I ended up fixing the issue, what I needed to do was reserve IRQ5 and DMA1 to Legacy ISA mode rather that PCI PnP
Reply 1 of 14, by Dolenc
Theres a driver install procedure on winXp that will give a3d support, the sound can crack a bit in some games with a3d enabled but for your case doesnt matter.
You should try it, xp is better with managing resources and at least you will get confirmation that everything really works. Not just, it worked once.
Maybe its something dumb, as just the contacts on the pci are a bit dirty and card just needs to be reinserted.
Reply 2 of 14, by SScorpio
Does Device Manager should the device and driver are loaded without error? Are there any messages in the event log?
If it appears to work but there's no sound, are you just using the front stereo output? If so try the rear with a 3D sound demo. Maybe something is dodgy with the front jack or amp. And the rear working or not could narrow it down to either a hardware or software issue.
If you haven't also remove the card and clean the contact pins and try different PCI slots.
Reply 3 of 14, by HellFire376
Dolenc wrote on 2023-05-06, 13:54:
I'll see about trying then once I get a chance, and maybe i'll need to see if the pins are dirty
Reply 4 of 14, by HellFire376
SScorpio wrote on 2023-05-06, 14:18:
yes it shows the device and drivers, it even shows there are no errors and that it works fine. I've gotten the card to somewhat work now with the version 2015 drivers, but now it's freezing up after a while of playing MIDI files or using games like duke nukem 3d
Reply 5 of 14, by shevalier
HellFire376 wrote on 2023-05-05, 18:24:
At VIA based motherboard you should firsteble instal VIA-4-in-1 chipset driver.
Or get such glitches ....
Aopen MX3S, PIII-S Tualatin 1133, Radeon 9800Pro@XT BIOS, Audigy 4 SB0610
JetWay K8T8AS, Athlon DH-E6 3000+, Radeon HD2600Pro AGP, Audigy 2 Value SB0400
Gigabyte Ga-k8n51gmf, Turion64 ML-30@2.2GHz , Radeon X800GTO PL16, Diamond monster sound MX300
Reply 7 of 14, by shevalier
Try installing Windows 2000 to test.
On buggy hardware, it is usually not installed or BSODed.
Reply 8 of 14, by Krzysztof Zakrzewski
I have two fully functional Aureal Vortex 2 cards with the AU8830A2 chip. One is a Diamond MX300, and the other is a product by Aureal.
I’m using Windows 98 SE on a retro PC with a Pentium 3 1.4. Generally, both cards work great in Windows and DOS.
However, when playing certain games with A3D sound, like Soldier of Fortune or Quake 3, there are cases where the game crashes with an AU30WAVE(5) driver error, regardless of which card is used. I’ve tried several drivers, including 2021, 2048, and definitely some older versions, but the crashes persist.
Is this a driver issue, or could it just be that some games inherently have this problem, and I should just accept it?
Reply 9 of 14, by bertrammatrix
Krzysztof Zakrzewski wrote on 2024-12-30, 13:23:
I have two fully functional Aureal Vortex 2 cards with the AU8830A2 chip. One is a Diamond MX300, and the other is a product by […]
I've used mine in several P3 systems with win 98, I don't think I've ever had any issues with games, definitely not with quake 3
Reply 10 of 14, by Krzysztof Zakrzewski
bertrammatrix wrote on 2024-12-31, 21:42:
Generally, games run based on the example of Quake 3 (version 11.1, as this version supports A3D). However, there are locations that cause crashes with the error AU30WAVE(5) driver error. The same issue occurs with Soldier of Fortune. You can progress through a few levels, but eventually, you encounter a location that causes a crash.
Reply 11 of 14, by bertrammatrix
Krzysztof Zakrzewski wrote on 2025-01-01, 17:44:
Just out of interest- have you tried a different pci slot?
Reply 12 of 14, by Krzysztof Zakrzewski
bertrammatrix wrote on 2025-01-01, 21:21:
Yes, I tested it in each of the three PCI slots.
I also changed the assigned IRQ address, but it made no difference.
For context:
In general, the card works fine in both DOS and Windows 98 SE.
Games with A3D run correctly, for example, Unreal Tournament works flawlessly without crashing.
The crashes occur in Quake 3 and Soldier of Fortune in A3D sound mode, but they are not frequent and happen under the same circumstances. I haven't experienced errors in other games.
Reply 13 of 14, by bertrammatrix
This thread:
Quake 3 and A3D
mentions that there are several versions, some with A3D, some not, some better then others, maybe worth looking into. It sounds like the implementation may have been buggy and removed from game options in later versions as a result.
Reply 14 of 14, by Joseph_Joestar
bertrammatrix wrote on 2025-01-02, 01:15:
This thread: […]
This thread:
Quake 3 and A3D
I never had issues with A3D 2.0 in Quake 3 on my Vortex 2, other than the setting needing to be turned back on each time you start the game (it doesn't get saved). As mentioned in the thread that you linked, A3D support was removed with patch 1.25. All versions of Quake 3 prior to that still support it. For example, you can safely apply patch 1.17 and A3D will work just fine.
As for the quality of the implementation, I thought it was pretty good. If you properly set up your Vortex 2 for headphone use, you can often pinpoint enemies by sound alone. This can sometimes give you an edge in a competitive environment.
