First post, by oh2ftu
It's seems like it's the time of the month were I have all those ideas that never get done.
As I look around my workspace I have quite a few (half a dozen or so) motherboards with a CPU and RAM installed to be used as some sort of test bench.
Powering on and debugging these would benefit from using pushbuttons, leds and buzzers instead of just a screwdriver to whack the two pins together.
Also, as we know, our beloved retrohardware didn't standardize any sort of front panel pinout on the mobo.
I was thinking of a small PCB that would house two leds, two buttons and a buzzer.
This would connect to the motherboard with either soldered or via a pin-header connected dupont-cables.
Cheap to make, make one for every motherboard I have and leave it connected.
It would also have an output header that would be of "modern standard". This could be used to connect to any case easily - and detach if needed.
Has anyone ever come across something like this?
I'm thinking a pcb with smd components (less risk for shorts) and/or a 3d-printed small case.
I might be out there again, and need to regulate my caffein-input. Let me know.
