First post, by Jackhead
- Oldbie
This time its based on the first Asus Maximus Formula sockel 775 X38 Mainboard.
The option using time correct case was gone with the decision of use an custom watercooling system.
So choosing a modern case i find the fractal north xl in black interesting. The XL Version can handle my radiator i want to use. And maybe more if i need..
When i was looking for a GPU i found a little nice setup of two 7950 GX2, both with an waterblock installed. Still have one with the air coolers.
It should be my new XP pc up to DX9.
The Asus has two full x16 pcie slots what makes it interesting for me to try the two GX2. Will see how this work out at the end.. One should be also totaly fine.
I just started the build, so it will be a buildlog here. All the parts will come in next days..
Parts List so far:
Board: Asus Maximus Formula X38 LGA775 Rev 1.03
CPU: Q9550 - cooled with cuplex kryos HF
RAM: GeIL EVO One 1066 CL5-5-5-15 - 2x 2GB
GPU: 2x Nvidia Geforce 7950 GX2 - quad SLI
SPU: Asus Supreme2 FX pcie x1
PSU: 850W be quite! straight Power 11 CM
Case: Fractal North XL black
Custom water cooling from Aquacomputer parts
Lets start with some pictures from the parts i got so far:
Its 360 radiator from aquacomputer i had for some time. The kryos is waiting for a adapter kit to fit the 775 socket.
Dos 6.22: Asus VL/I-486SV2GX4 Rev 2.0 1Mb L2 - A5x86 X5 P75 - 64MB - AHA-2842A VLB - ET4000W32P VLB - CT2230 - GUS ACE - MPU-401AT with YucatanFX
Win98SE: Asus P5K-WS - E8600 @ 4,5GHz - Strange God Voodoo 5 6000 PCI-X - 2GB DDR2 1066 - Audigy 2 ZS
