Midi out
First post, by lagunalore
HI there, i continue using dosbox but now i have a new problem, i want to use doxbox midi music to record it in midiox, does anyone know how can i redirect the dosbox midi music to a port called out to midi yoke 1?? Thank you!!
Reply 1 of 2, by Qbix
Rank DOSBox Author
DOSBox Author
you can save the midi streams with dosbox itself as well.
there is some keycombination that does this. It is in the readme.
Water flows down the stream
Reply 2 of 2, by lagunalore
Thank you, i have saved the music without midiox, with dosbox was enough. Bye!
