First post, by Cursed Derp
- Oldbie
Heyyyo,
In the video forum I have recently discussed an AGP Nvidia card that I picked up from a thrift store. I bought it thinking it was an FX 5200 and a few of you offered some speculation on what the card was. The final verdict was that it was either an FX card or some type of Quadro. The only way to know was to find out, so I purchased an Svideo cable from Amazon (sorry for the long link:
https://www.amazon.com/Traovien-Connector-Cam … yY2hfYXRm&psc=1
I installed the card in my pc today. It took a while as the card's bracket appears to be somewhat bent:
The bend is very close to the svideo port:
It took a lot of work to get it into the agp slot because the bracket was bent enough to make it difficult to insert.
I attached the svideo cable to the card and the monitor:
I switched to the svideo input and turned on the pc after this and was greeted by the usual flashing dash, although it appeared to be more blurry and in worse definition than with the usual vga output:
There appears to be a blurry frame around the actual output.
The dash disappears after a few seconds and after that the screen just goes black except for the blurry frame around the image. The pc sounds correct and the hard drive (I think) and the fan are running consistently. Everything is at a lull and no extra sounds happen. I don't think the usual boot menu comes up or anything. The hard drive doesn't get louder.
Is my card bad? Is this a known problem? I haven't used svideo before so I'm very inexperienced with this type of output.
If anyone has any advice or information, I would greatly appreciate it.
Thank you
I am as smooth as a gravy train with flaming biscuit wheels.
