Reply 2180 of 3377, by sharangad
And I think I've figure out why Descent II doesn't work properly:
The game reports this in the console window:
Available memory
Conventional : 622 KB
Extended : 63,244 KB
Virtual: 192,756 KB
From where does it get 192 MB of virtual memory?
https://www.youtube.com/@sharangadayananda\
https://patreon.com/Rready
Reply 2181 of 3377, by gplaps
I have made a small overview video of the Wrapper with ICR2 with tutorial on how to install to show this great work to a larger audience!
https://www.youtube.com/watch?v=iV7kTvOS_t0
Reply 2182 of 3377, by sharangad
gplaps wrote on 2025-01-09, 12:06:
Wow! That looks amazing!
Reply 2184 of 3377, by sharangad
RaVeN-05 wrote on 2025-01-09, 13:36:
helped on ms website about troubles on dosclient
Thanks dude! I have no idea why it's repeatedly flagging stuff. It's a ton of hassle.
Reply 2186 of 3377, by RaVeN-05
looked whole video, amazing , thank you! )
Hoping dosclient issue will be resolved.
other ways is to recompile / reorganize it somehow so false sequence of bytes get rid , ones which detected by
https://www.youtube.com/user/whitemagicraven
https://go.twitch.tv/whitemagicraventv
Reply 2187 of 3377, by sharangad
RaVeN-05 wrote on 2025-01-09, 16:56:
looked whole video, amazing , thank you! ) […]
It might be because it's using named pipes to communicate. That's like a socket connection. In this case it's local: dosbox-rendition to dosclient.
Reply 2188 of 3377, by supererwin
Hi!
I just tested your awesome work, but it could not start properly. All I get is a white window, which states "60 fps" at the top left, but I cannot see any picture content. The logfiles keeps saying
22:09:16.753 1936 [0] GL Error GL_INVALID_OPERATION (1282) : RenderToMultiTexture::StartCapture entry
What could I be doing wrong?
Thanks in advance,
supererwin
Reply 2189 of 3377, by RaVeN-05
Waiting Sharanga response, meanwhile i can say try disable fps and if its happening for icr2 try disable frame interpolation. this one is helps for my old video card.
maybe your case is another...
Reply 2190 of 3377, by supererwin
Hello RaVeN-05!
Thank you! Disabling Frame Generation did the trick (I tried all the other settings before, but not that one - my bad!). I'd love to have frame generation as like this I only get 30 fps, but at least it works now - and looking awesome! GREAT WORK!
supererwin
Reply 2191 of 3377, by sharangad
supererwin wrote on 2025-01-09, 21:22:
Hi! […]
Hi!
Thanks in advance,
supererwin
What's your gpu and cpu? Also could you post your log files here: just click the "zip log files" button and it should zip them up show the zip file in explorer.
[EDIT] that should just work.
Reply 2192 of 3377, by sharangad
Hi! […]
Hi!
Thanks in advance,
supererwin
Also try lowering your upscaling resolution, it might be running out of gpu vram.
Reply 2193 of 3377, by sharangad
supererwin wrote on 2025-01-09, 21:57:
Hello RaVeN-05!
supererwin
What's your screen resolution and how much vram have you got?
Reply 2194 of 3377, by sharangad
Anyone testing ICR2, does replacing your .CFG files with these boost your framerates (backup the existing files)?
https://nirvtek.com/downloads/IndyCar.Configs.7z
This disables car damage and weather, with the installatin of ICR2 @gplaps shared I get very low framerates with Downtown Detroit, not entirely sure why. I don't see anything wrong in the logs.
Reply 2195 of 3377, by sharangad
RReady Alpha, January 10, 2025 (Untested Store Release candidate)
This will be undergoing testing shortly
https://nirvtek.com/downloads/RReady.Alpha.20250110.001.7z
MD5: 7a07f529eade3ed5aae43a6a5c0c8724
- Tomb Raider 1 video cutscenes should now render on Win11 24H2 with Nvidia hardware and possibly on most Intel integrated GPUs.
- ICR2 by default disables Rendition anti-aliasing which makes the game runnable on GPUs with less VRAM, such as Intel HD graphics. It also provides a significant performance boost on such systems.
- ICR2 – RLauncher now offers control over fogging, bilinear filtering and low res mirrors (original game resolution). Additionally options to disable line drawing and Rendition Anti-Aliasing are available. The latter two are turned off by default as custom carsets have issues with this, even on original hardware. They can be turned back on for purists.
- Whiplash original low res mirrors can be enabled.
- SDK Demo Ucube.exe should now once again render correctly in full screen mode.
Reply 2196 of 3377, by BEEN_Nath_58
sharangad wrote on 2025-01-10, 10:24:
***************************************** RReady Alpha, January 10, 2025 (Untested Store Release candidate) This will be undergo […]
Intel has issues running DOSBox videos as well?
Reply 2197 of 3377, by supererwin
sharangad wrote on 2025-01-10, 02:57:
Hi!
Yes, I am testing with ICR2, got attention due to the awesome video of GPLaps. Always enjoying his content.
Here's my setup:
AMD Ryzen 5 5500 3,6 GHz
32 GB RAM
Windows 10 Pro 22H2
AMD Radeon RX 7900 XT
Fanatec Podium Wheel Base DD2
Fanatec Clubsport Steering Wheel F1 2019
Fanatec CSL Elite Pedals
I ran the program again in such a way that it flickers and does not show any picture but a white window in order to create the logfiles. The setup of your software can be seen in the screenshot attached. I hope, this helps.
BTW another question: I cannot seem to use the key mappings within ICR2. I can't locate the dosbox-mapper file after saving plus: I can use the mapped buttons on my wheel for shifting in the control config menu, but in game, hese buttons are just out of function. Any idea? This only happens in "your" ICR2. If I use my common ICR2 without Rendition, it works just fine...
Feel free to use me as beta tester. I am willing to support your work the best way I can (although time is a limiting factor here...).
All the best,
supererwin
Reply 2198 of 3377, by sharangad
@gplaps, could you reply to @michaelgott9524 (who commented on your video about being unable to buy the wrapper) to try it from the Microsoft Store app and search for RReady and make sure his region is set to the UK. I think the link is for the US store.
I posted a link in the comments section of the video and appear to be locked out of commenting.
Reply 2199 of 3377, by sharangad
supererwin wrote on 2025-01-10, 11:24:
Hi! […]
Hi!
Here's my setup:
32 GB RAM
Windows 10 Pro 22H2
All the best,
supererwin
At last an AMD GPU user. Those are few and far between these days. I'll check out your logs right away.
