Reply 2200 of 3377, by sharangad
- l33t
supererwin wrote on 2025-01-10, 11:24:Hi! […]
sharangad wrote on 2025-01-10, 02:57:What's your screen resolution and how much vram have you got?
Hi!
Yes, I am testing with ICR2, got attention due to the awesome video of GPLaps. Always enjoying his content.
Here's my setup:
AMD Ryzen 5 5500 3,6 GHz
32 GB RAM
Windows 10 Pro 22H2
AMD Radeon RX 7900 XT
Fanatec Podium Wheel Base DD2
Fanatec Clubsport Steering Wheel F1 2019
Fanatec CSL Elite PedalsI ran the program again in such a way that it flickers and does not show any picture but a white window in order to create the logfiles. The setup of your software can be seen in the screenshot attached. I hope, this helps.
BTW another question: I cannot seem to use the key mappings within ICR2. I can't locate the dosbox-mapper file after saving plus: I can use the mapped buttons on my wheel for shifting in the control config menu, but in game, hese buttons are just out of function. Any idea? This only happens in "your" ICR2. If I use my common ICR2 without Rendition, it works just fine...
Feel free to use me as beta tester. I am willing to support your work the best way I can (although time is a limiting factor here...).
All the best,
supererwin
Hi
Can you try this build and get me the logs, even if it works, I need the logs.:
https://nirvtek.com/downloads/RReady.Alpha.20 … .002.AMDTest.7z
MD5: 68d4cefebcc045a8d27f0b9e999997db
PS I don't think it'll work.
https://www.youtube.com/@sharangadayananda\
https://patreon.com/Rready
