First post, by Jackhead
I got a EGA/VGA card that should work on my CGA IBM 5153 monitor.
Little confused what dip switch setting i should use.
There information here: https://dosdays.co.uk/topics/Manufacturers/at … _wonder_vip.php
Should i use IBM Analog?
Dos 6.22: Asus VL/I-486SV2GX4 Rev 2.0 1Mb L2 - A5x86 X5 P75 - 64MB - AHA-2842A VLB - ET4000W32P VLB - CT2230 - GUS ACE - MPU-401AT with YucatanFX
Win98SE: Asus P5K-WS - E8600 @ 4,5GHz - Strange God Voodoo 5 6000 PCI-X - 2GB DDR2 1066 - Audigy 2 ZS
Reply 1 of 4, by Grzyb
"RGB (& Composite)"
Nie rzucim ziemi, skąd nasz root!
Reply 2 of 4, by Jackhead
Grzyb wrote on 2025-01-08, 13:31:
"RGB (& Composite)"
thanks!
Reply 3 of 4, by rmay635703
"RGB (& Composite)"
What a poorly written manual.
You would think they could describe CGA better than RGB
IBM CGA was 16 color ttl
AKA RGBi + HV Sync
“Analog” wasn’t an IBM standard and was usually 15khz RGB+s Analog which was a Commodore/Amiga standard or Targa
Some old multi format screens would have dips for TTL 4, 16, 64 color and ANALOG
and selections for CVBS/NTSC
Reply 4 of 4, by Grzyb
rmay635703 wrote on 2025-01-10, 04:24:
That card is primarily VGA - the "IBM Analog" selection must be for VGA monitors, 31 kHz.
For them, there's the "MultiSync" selection, 15..35 kHz, up to 800 x 560.
