Help concerning VBE/VESA in DOS
Reply 20 of 26, by Gmlb256
DustyShinigami wrote on 2025-01-11, 16:25:
From what I’ve read, 53a supports Discworld 2, but surely a later version would work fine as well…? I can’t use 53a because that also complains there’s no supported device. And I have no Nvidia patch for that. I’m guessing there isn’t one either?
If I’m having these problems with an old Riva TNT, I can’t see me having much luck with my GeForce 4 MX 440 if that’s newer. 😕
Since SDD 5.3a only supports NV1 when it comes to nVidia and you are having troubles, check the following modded drivers: Re: VESA Fix Utility Listing (for old video cards). These are much straightforward than NVPatch and directly uses the VBIOS of the video card.
There won't be 15bpp nor certain lower resolution VESA video modes though.
Reply 21 of 26, by DustyShinigami
Gmlb256 wrote on 2025-01-11, 17:11:
Oh cool. Thanks for the link. And that's fine. I doubt I'll be in need of 15bpp or lower resolutions to be honest. 😀 I'll give these modified drivers a try and report back.
OS: Windows 98 SE
CPU: Slot 1 Pentium III Coppermine 933MHz (SL448)
RAM: Kingston 256MB 133MHz
GPU: Nvidia 16MB Riva TNT
Motherboard: ABit AB-BE6-II Intel 440BX
HDD: 30GB - IDE 3; 40GB - IDE 3; 80GB - IDE 4
Reply 22 of 26, by DustyShinigami
Had some issues getting the fix utility to work. Was about to give up, especially as the utility only enables some extra resolutions and colour depths, which isn't what Discworld 2 needed to install. But then I did some further experimenting...
I decided to try copying the contents of the CD to a folder in DOS. Then I deleted all the VBE related files, particularly uvconfig.dat, uvconfig.exe, and I think univbe.drv. The installer loaded up, but I think it was messy. Like with BS1 and how the image was in a rectangle at the top of the screen and flickering like crazy. So I tried replacing the files by adding the VBE files for 5.3, including the driver. If I remember right, I think the installer displayed correctly! However, when installing, it would get halfway and fail. But then after installing the VBEPlus utility, it seemed to do the trick!
I did try doing some further experimenting for BS1's flickering mouse cursor, but still no dice. However, I'm going to try copying the contents of the CD to the HDD, delete the VBE files, and then burn it all to a blank CD. And/or try adding the other VBE files. See if preventing the game to use the provided VBE drivers helps.
OS: Windows 98 SE
Reply 23 of 26, by DustyShinigami
Well, I've copied the contents of BS1's first disc to the HDD and removed the VBE files on there. Loading up the executable in Notepad, it mentions that it uses version 5.2, so it's not far off from the version needed for Discworld 2. I'll see later if removing the files from the disc makes any difference when loading the game from it. I suspect probably not. The experiment with Discworld 2 did work by removing the files, but that was to get the installer working. If VBE drivers have no bearing on the mouse flicker, I've absolutely no idea what's causing it.
OS: Windows 98 SE
Reply 24 of 26, by DustyShinigami
Yeah, it doesn't work. I get a similar error when trying to run the game as when I tried to load Discworld 2's installer. So I'll try adding VBE 5.3 to the root of the CD contents and try that. Might even try reinstalling the game from scratch using this 'modified' CD.
OS: Windows 98 SE
Reply 25 of 26, by DustyShinigami
Yeah, I’ve essentially given up. I’m totally out of ideas. I tried. I’m not sure if it is a VBE issue with the game. Maybe it’s just a quirk with the original CD-ROM/DOS release of the game.
At any rate, looks like I hadn’t set up the contents of the modified disc correctly. Plus I’d failed to copy the subdirectories when I last copied the contents of the original disc to the HDD. Did it correctly this time and then replaced the VBE files from the disc with those from both 5.3 and 6.53. Reinstalled the game from the HDD a number of times as well. The game loaded up fine with each version, but the flickering cursor remained.
So I’m moving on. At least I got the VBE driver issue sorted for the DOS version of Discworld 2, so it wasn’t a total loss. 😀
OS: Windows 98 SE
Reply 26 of 26, by DustyShinigami
Not sure I should carry on with this thread or start another one? I've done all I can regarding VBE and fixed one game that needed it anyway. However, regarding the flickering issue in BS1, I believe I've found out the problem. And it was simple all along. Like a lot of these classic adventure games in DOS, the CPU speed is too fast. So I need some advice regarding a CPU throttler.
I only briefly touched on a CPU throttler for the game and it made no difference. However, that was only by disabling the L2 cache. Using Throttle, I experimented with the different speed options and that has helped, to an extent. What I need though, is a CPU throttler that gives me more control. I need something between setting 2. and 3. 2 sets the speed to 25% slow whereas 3. sets it to 37.5% slow. I need something inbetween. So I can slow it down around 30%.
The 'safevideo' command fixes the flickering sprites, but introduces a flickering cursor. If I play the game as normal without the command, the sprites flicker, but the cursor is fine. Setting Throttle 2 still gives me sprite flicker. Setting it to 3 eliminates the flicker, but introduces some stutter during animations, hence why I need to fine tune things manually, if possible. 😀
OS: Windows 98 SE
