First post, by TheFriedLemon
I've been searching about this 40pin laptop ide connector but found nothing about it.
Reply 1 of 13, by dionb
Good question. The regular laptop PATA connector is 44p at 2mm pitch, not 40p, with the additional 4 pins being for power.
What system / which drives are these images from?
Reply 2 of 13, by TheFriedLemon
dionb wrote on 2025-01-12, 18:28:
its a Unisys powerport NB40, also the other end of the ribbon cable that connects to the drive is a 44pin
Reply 3 of 13, by TheFriedLemon
I was just looking for a replacement cable for it
Reply 4 of 13, by TheFriedLemon
That's what the full ribbon cable looks like
Reply 5 of 13, by AlessandroB
Can be SCSI? 2,5” scsi hard drive had 40 (or 44, i can’t remenber) connector.
Reply 6 of 13, by dionb
That looks pretty proprietary then. Also, if the right hand connector is a standard 44p 2.0mm pitch connector, the left hand one has smaller pitch as well. Afraid your best hope is finding the service manual of the laptop, getting the Unisys part number from there and see if anyone is offering them for sale.
Don't think it was 2.5" SCSI, IIRC they used 50 pin SCSI DIL 0.1” Connector
Reply 7 of 13, by TheFriedLemon
dionb wrote on 2025-01-12, 22:19:
It plugged in a regular 44pin drive
Reply 8 of 13, by ElectroSoldier
Its a standard 40 pin IDC on a proprietary cable.
I would say it was par for the course in old laptops. Its wired straight through too so while it will be almost impossible to find an official replacement any 40 pin cable could do the job if it fits.
Reply 9 of 13, by TheFriedLemon
ElectroSoldier wrote on 2025-01-12, 23:05:
Is there any example that might fit?
Reply 10 of 13, by ElectroSoldier
TheFriedLemon wrote on 2025-01-13, 04:03:
Do you mean an "off the shelf" item?
I doubt it.
I noticed looking at the photo the tracks on the ribbon on the connector next to the L key looks like it has track damage.
Is that why you need another one?
Reply 11 of 13, by TheFriedLemon
ElectroSoldier wrote on 2025-01-13, 05:26:
Do you mean an "off the shelf" item? I doubt it. […]
I doubt it.
Yeah the cable is broken
Reply 12 of 13, by ElectroSoldier
TheFriedLemon wrote on 2025-01-13, 10:13:
I doubt it.
I would not know where to start looking for a direct replacement for it.
Maybe some of the guys here will know where you can get a spare/replacement.
I would be looking to repair it, either yourself or somebody who can repair it.
Reply 13 of 13, by AlessandroB
2,5 drive use less conductor, tomorrow i make a pics of mine
