First post, by kotel
- Oldbie
Recently got this MSI MS 6163 PRO board from scrap. Inspection revealed no broken stuff. Powered it on without issues.
Now, when I was getting ready to install 98se I came across a weird behaviour. The board hangs every time there are two drives present on one IDE bus.
I am using an 40pin cable (80pin made the same issue), 8GB HDD and philips combo drive, so HDD being too large isn't the cause. Everything works if there's one drive on the bus. BIOS isn't the latest (can't risk killing my only slot 1 board).
Anybody knows how to fix this behavior?
"Sent on a mission, to protect the last treasures. Through struggle and strife we can see the light. Even if our mission is partially complete, Our efforts are not in vain.
Let that be our legacy."
-Stronghold 5-5
