First post, by songoffall
- Member
Long story short, after plugging the NIC into the motherboard, the PC won't POST. I took out the GPU and then the RAM, expecting the motherboard to scream at me, but no error codes. Lights turn on, fans run, no signal to the monitor.
Here are the troubleshooting steps I tried:
- Take out the NIC from the PC. The PC POSTs and boots like normal.
- Plug the NIC into a different PCI slot (there's 2 PCI devices and one AGP device on this computer). No POST.
- Remove other PCI cards, plug the NIC into the motherboard. No POST.
- Plug the NIC into a different computer. The PC posts, the NIC is detected by the system.
I would assume 3COM cards were more compatible than other brands. Are there any known incompatibilities with this particular card and the Intel 865P chipset? Am I missing something?
Another thing that surprised me, whenever I plug the NIC into a motherboard, any motherboard, and connect the power wire to the PSU, the yellow light (indicating 100Mbps connection) on the NIC lights up, even though there's no ethernet cable plugged into it.
Pentium 2 300MHz/Matrox Mystique/Sound Blaster AWE 32 Value
Pentium 3 733MHz/3dfx Voodoo 3 3000/Aureal Vortex 2 (Diamond Monster Sound)
Pentium 4 2.0GHz/GeForce4 Ti4200/Sound Blaster Live!
Core2Duo Q9400/GeForce 8800GT/Creative X-Fi Titanium Fatal1ty
