Reply 55760 of 56737, by BitWrangler
Cool. That EGA card fits exactly to the memory of the one I had in the 90s. It was that one I was able to get a mono signal out of into a PAL security monitor that had plenty of vertical hold range.
Reply 55761 of 56737, by GigAHerZ
I think i've gotten myself now the "perfect testbench" motherboard: ASUS P2B-VM - https://theretroweb.com/motherboards/s/asus-p … -vm-3d-rage-pro
  • SLOT 1
  • 440BX
  • 133MHz FSB supported (Tested with Pentium III 866MHz which has 133MHz FSB)
  • No FSB auto-detect - just jumpers, full control
  • ESS Solo-1 integrated sound - really good one for DOS, too
  • mATx - small and nice, while still having AGP, PCI and ISA to play with
  • Updates bios to the latest from RetroWeb (1014 beta) + added Bios Patcher 4.23 fixes on top. (Submitted that bios to RetroWeb)
133MHz will push the AGP out of spec quite a bit. Therefore I'm running it with Celeron 800MHz with 100MHz FSB. 3DMark2001 shows a tiny edge on 800MHz Celeron over 650MHz P3. (866MHz P3 downclocked to 100MHz FSB)
I absolutely love it!
Reply 55762 of 56737, by Pino
Trashbytes wrote on 2025-01-16, 04:40:
Also grabbed a 1.6v K6-2+400 for 19 bucks which should overclock much better and might be able to be modded into a full K6-3+, good thing the entire process is here on Vogons.
Just received mine, probably bought from the same vendor.
Does 550Mhz at 2.0V easy. Crashes if I go 600Mhz, I haven't tried anything above 2.0V yet.
I just removed the lid on my other K6-2+, a 500 model, will try the mod this weekend once I receive my new magnifying glasses 😀, I'm too old for SMD components
Reply 55763 of 56737, by Trashbytes
Jccwu wrote on 2025-01-17, 15:34:
Trashbytes wrote on 2025-01-17, 08:06:
PcBytes wrote on 2025-01-17, 07:57:
And another win - ABIT BX133-RAID. Should fit nicely in the case I posted earlier.
Truly a beast of a board, one I consider to be the pinnacle of the BX chipset.
not so beast. AGP2x, no support Tualatin default. Compared to this board, Chaintech 6AJAT and Gigabyte GA-6VTXE boards look much better. The only advantage here is the additional IDE channel, but who needs it?
Here is Universal AGP and ISA slot with Tualatin support.
Yeah Im not fan of VIA chipsets unless its the Apollo Pro 133T or the Apollo Pro 266T both are exceptional but to be expected being the last of their respective families, the 266T is one of the few chipsets that supported both DDR and Tualatin but finding it on boards is difficult as it was released right at the tail end of Tualatin, I would say its almost as rare as getting the SiS 635T chipset which also supports Tualatin and DDR.
I have several SiS 635T boards and they are exceptionally fast right out of the box and allow some stupidly fast FSB overclocks. I dont yet have any 266T boards ..mostly due to them being silly expensive when they do show up on Evilbay.
But for the BX chipset the BX133-Raid is right at the top, its a highly compatible rock solid board that will support Tualatin with a little work and if looked after will run solid for years on end, I have one I use for an AGP test bench because itll pretty much work with any old AGP 2X/4X card and if a card doesnt work in that board then I can safely throw it into the spares/repairs box knowing its almost certain to be dead.
Reply 55764 of 56737, by smtkr
Is DDR even useful for a Tualatin? Am I thinking about this correctly? You double the memory pipe, but the CPU has half the bandwidth, so you have twice the memory bandwidth that the CPU can handle. You ideal scenario is that you saturate the FSB AND you have some room for DMA operations?
Reply 55765 of 56737, by Trashbytes
smtkr wrote on 2025-01-17, 23:47:
In day to day use I would say no, its not needed.
But for overclocking which both these chipsets cater to I would say its very nice to have and the Tually scales pretty well once you start increasing the FSB, 160+ FSB isn't impossible, but at the end of the day it'll still be at max DDR 266 you are using not DDR400.
The other point is that the 266T chipset is usually found on dual CPU server boards where DDR can be an advantage.
One day I will get my hands on a QDI Advance 12T and complete my Tualatin board collection !
Reply 55766 of 56737, by Duffman
There's this chinese socket 370 board bundled with a CPU, RAM and AGP card on ebay.
https://www.ebay.com/itm/235608712940
Anyone used a CYSMBD-694X motherboard before?
MB: ASRock B550 Steel Legend
CPU: Ryzen 9 5950X
RAM: Corsair 64GB Kit (4x16GB) DDR4 Veng LPX C18 4000MHz
SSDs: 2x Crucial MX500 1TB SATA + 1x Samsung 980 (non-pro) 1TB NVMe SSD
OSs: Win 11 Pro (NVMe) + WinXP Pro SP3 (SATA)
GPU: RTX2070 (11) GT730 (XP)
Reply 55767 of 56737, by sfryers
I got hold of two Celeron 300A's including coolers, for a decent price:
The attachment Celeron_300As.jpg is no longer available
They certainly live up to their reputation for being legendary overclockers- both are fully stable at 450MHz (4.5x100) on stock voltages. The one with the black heatsink will boot into Windows at 504MHz (4.5x112) and even runs 3DMark 2000 for a minute or two before it crashes. I think I'll try it again with a little voltage boost 😀
MT-32 Editor- a timbre editor and patch librarian for Roland MT-32 compatible devices: https://github.com/sfryers/MT32Editor
Reply 55768 of 56737, by myne
Duffman wrote on 2025-01-18, 11:36:
https://theretroweb.com/motherboards/s/cys-tech-cysmbd-694x
Might be a gigabyte clone
I built:
Reply 55769 of 56737, by AGP4LIfe?
Well....!!! Found me a little treat inside a Getaway Select tower 😁
I'm scared to take it out! don't want to damage anything.. 😳
The attachment PXL_20250118_222303580.jpg is no longer available
Who decides what truth is, and what is their objective? Today’s falseness can reappear as tomorrow’s truth.
Reply 55770 of 56737, by Trashbytes
myne wrote on 2025-01-18, 14:59:
It certainly looks like one.
Reply 55771 of 56737, by PcBytes
Trashbytes wrote on 2025-01-18, 23:18:
It is, exact replica of Gigabyte GA-6VXC7-4X-P, except they traded AMR slot for onboard audio (a good choice since nobody uses AMR anyways), and it uses Award BIOS instead of AMI.
AGP4LIfe? wrote on 2025-01-18, 22:27:
Welp, guess I know what my next CPU to buy will be, after the K6-III+ arrives.
Reply 55772 of 56737, by BitWrangler
I didn't even have a crappy PCIe soundcard in case I needed one, so now I've got a crappy PCIe soundcard in case I needed one. A SB1570 turned up in a thrift for like 10% new price, so it came home with me. Just the Audigy FX, HDA and software EAX. Might end up in a Core2 Quad Vista box or something, if it will work there. Then hopefully can assign affinity of EAX stuffs to 4th core, since that will tend to get barely loaded with anything.
Also there for pocket change were a couple of ATX2ATX-N03 adapter for synching power up of dual PSU. You plug primary 5.25 molex into it and uses a relay to kick in the the powergood of the secondary ATX psu. Could be handy at some point or I could tag P8 P9 connectors to back and misuse them as converters, or when I'm running out of decent AT PSUs, I might use a weakass one of those as primary, and a weakass ATX as secondary to power all the drives or something.
Reply 55773 of 56737, by Trashbytes
PcBytes wrote on 2025-01-19, 00:02:
It is, exact replica of Gigabyte GA-6VXC7-4X-P, except they traded AMR slot for onboard audio (a good choice since nobody uses A […]
hehe you know you want one, the 950 is pretty damn hard to get though almost as hard as the 1000. Plenty of 700s and 850s around though.
Reply 55774 of 56737, by Nexxen
Trashbytes wrote on 2025-01-19, 00:23:
700s are cockroaches. You open a drawer and one is there. 🤣
PC#1 Pentium 233 MMX - 98SE
PC#2 PIII-1Ghz - 98SE/W2K
"One hates the specialty unobtainium parts, the other laughs in greed listing them under a ridiculous price" - kotel studios
Reply 55775 of 56737, by Trashbytes
Nexxen wrote on 2025-01-19, 00:30:
950s and 1000 are like that spider you know is watching but you cant find it ...but its there silently watching and waiting from the dark.
Reply 55776 of 56737, by Nexxen
Trashbytes wrote on 2025-01-19, 00:34:
🤣 🤣 Good one!
1000 I never even saw one live. Just have some socket A Thunderbird + SDRAM mobo and that's how close I'll ever get unless a miracle happens.
Reply 55777 of 56737, by Ozzuneoj
Nexxen wrote on 2025-01-19, 00:46:
🤣 🤣 Good one!
One snuck up and bit me a few years ago. 😁
Reply 55778 of 56737, by PcBytes
As a wise man once said: "Good thing I brought my axe-cane."
Spiders or roaches, abandon hope all ye who dare oppose me!
Reply 55779 of 56737, by Trashbytes
PcBytes wrote on 2025-01-19, 04:13:
The great Lord Cthulhu mumbles in his sleep disturbed by some fool yelling at spiders.
