First post, by kotel
This is my first time ever seeing irl and using an MFM controller, so please excuse me 😀
Recently got an SMS FAB 0005476 REV B MFM controller card. No visible damage.
Plugged it into my ms6163 board correctly. BIOS didn't show any extra controller cards besides the intel one. Same as 98se (tried add new hw wizard). Weirdly the Zilog chip and the eeprom close to it get warm while the rest stay cold.
I don't have any MFM drives to test this card, so I at least want to see if this one is detected. I have no idea what I did wrong. Is this supposed to be an IBM pc or compatible MFM controller?
"Sent on a mission, to protect the last treasures. Through struggle and strife we can see the light. Even if our mission is partially complete, Our efforts are not in vain.
Let that be our legacy."
-Stronghold 5-5
Reply 1 of 7, by Grzyb
That controller is ISA 8-bit, primarily for XT-class PCs.
Your board is Slot 1, several generations later.
There's still a chance for them to work together, but:
- BIOS won't detect that controller as an ISAPNP or PCI device
- Windows 9x won't detect it, either
Without an appropriate drive, probably all you can do is to try to enter the Low Level Format utility contained in the controller's BIOS...
See also:
https://arvutimuuseum.ee/th99/c/S-T/20181.htm
https://arvutimuuseum.ee/th99/c/S-T/20182.htm
https://arvutimuuseum.ee/th99/c/S-T/20921.htm
https://arvutimuuseum.ee/th99/c/S-T/20922.htm
Nie rzucim ziemi, skąd nasz root!
Reply 2 of 7, by kotel
Weird how there's no pop up "detecting drives..." with that MFM controller. Oh well. Guess I'll wait tilt I get my hands on an IBM XT or clone PC.
-Stronghold 5-5
Reply 3 of 7, by Grzyb
MFM drives aren't detected.
If the controller's BIOS is enabled, it *may* display some message during POST.
But for anything more, you need to enter the utility from DEBUG.
Reply 4 of 7, by kotel
I don't see any jumpers for BIOS enable/disable other than HDD activity LED(?) and W1-8 jumpers.
-Stronghold 5-5
Reply 5 of 7, by Grzyb
kotel wrote on 2025-01-19, 08:32:
See the links I posted - W7 enables/disables the BIOS.
Reply 6 of 7, by kotel
W7 is opened, so the BIOS is enabled, or at least should be.
-Stronghold 5-5
Reply 7 of 7, by Grzyb
You can try to run DEBUG, and then:
G=C800:5
AFAIR, for some BIOSes the correct address may be C800:4 or C800:6
